Ana içeriğe geç
Samsung Chromebook 3 Motherboard Replacement
Neye ihtiyacın var
  1. Samsung Chromebook 3 Motherboard Replacement, Bottom Case: adım 1, 2 resimden 1. Samsung Chromebook 3 Motherboard Replacement, Bottom Case: adım 1, 2 resimden 2.
    • Place the Chromebook face down so that the bottom case is exposed.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 Motherboard Replacement: adım 2, 3 resimden 1. Samsung Chromebook 3 Motherboard Replacement: adım 2, 3 resimden 2. Samsung Chromebook 3 Motherboard Replacement: adım 2, 3 resimden 3.
    • Use a iFixit opening tool to gently pry the case up from the vent on the hinge side of the Chromebook.
    • You should hear a popping sound as the connectors disengage inside the case.
  3. Samsung Chromebook 3 Motherboard Replacement: adım 3, 1 resimden 1.
    • Lift the case up and off the device
  4. Samsung Chromebook 3 Motherboard Replacement, Battery: adım 4, 2 resimden 1. Samsung Chromebook 3 Motherboard Replacement, Battery: adım 4, 2 resimden 2.
    • Locate the battery and remove the four 4.6mm screws at the corners which attach it to case using a Phillips #00 screwdriver.
  5. Samsung Chromebook 3 Motherboard Replacement: adım 5, 2 resimden 1. Samsung Chromebook 3 Motherboard Replacement: adım 5, 2 resimden 2.
    • Use a spudger to gently pry the power cable cord upwards from the motherboard.
  6. Samsung Chromebook 3 Motherboard Replacement: adım 6, 1 resimden 1.
    • Lift the battery up and out from the case.
  7. Samsung Chromebook 3 Motherboard Replacement, Motherboard: adım 7, 3 resimden 1. Samsung Chromebook 3 Motherboard Replacement, Motherboard: adım 7, 3 resimden 2. Samsung Chromebook 3 Motherboard Replacement, Motherboard: adım 7, 3 resimden 3.
    • Before you can get to the motherboard, remove the three 4.6mm screws from the port cover using a Phillips #00 screwdriver.
  8. Samsung Chromebook 3 Motherboard Replacement: adım 8, 3 resimden 1. Samsung Chromebook 3 Motherboard Replacement: adım 8, 3 resimden 2. Samsung Chromebook 3 Motherboard Replacement: adım 8, 3 resimden 3.
    • Then, use a spudger to begin flipping up the grey covers on the ZIF connectors.
  9. Samsung Chromebook 3 Motherboard Replacement: adım 9, 3 resimden 1. Samsung Chromebook 3 Motherboard Replacement: adım 9, 3 resimden 2. Samsung Chromebook 3 Motherboard Replacement: adım 9, 3 resimden 3.
    • Two more ZIF connectors to go!
  10. Samsung Chromebook 3 Motherboard Replacement: adım 10, 2 resimden 1. Samsung Chromebook 3 Motherboard Replacement: adım 10, 2 resimden 2.
    • Use a spudger to disconnect the cables going to the speaker by prying outward to the right.
  11. Samsung Chromebook 3 Motherboard Replacement: adım 11, 3 resimden 1. Samsung Chromebook 3 Motherboard Replacement: adım 11, 3 resimden 2. Samsung Chromebook 3 Motherboard Replacement: adım 11, 3 resimden 3.
    • Use a spudger to lift the hinge locking the gold colored display cable in place.
    • Then gently coax the display cable from its connector using your fingers or a spudger.
  12. Samsung Chromebook 3 Motherboard Replacement: adım 12, 2 resimden 1. Samsung Chromebook 3 Motherboard Replacement: adım 12, 2 resimden 2.
    • Use your Phillips #00 screwdriver to remove four 4.6mm screws from the motherboard.
  13. Samsung Chromebook 3 Motherboard Replacement: adım 13, 1 resimden 1.
    • Ensure all cables are clear and remove the motherboard.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Austin Blakely
19.955 İtibar
53 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
140 Üyeler
18.078 adet Kılavuz yazıldı
Bir Yorum
Thanks for the great guide! I used it to remove the write protection screw on the back of the motherboard.
My Chromebook is model number XE501C13. The only difference I noticed is that there is one less screw on the outer plastic cover. Everything else is exactly the same!
Edward Fernandez - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 33
Her zaman: 3,018
