Ana içeriğe geç
Samsung DV180F Repair Display Screen Replacement
Evan McGettrick
Evan McGettrick ve 3 diğer katkıda bulunanlar
En son 22 Eki 2020 tarihinde güncellendi
10 - 15 dakika
Orta
This will consist of taking apart the camera by using the Phillips 000 bit and the smallest opening tool available in order to replace the back facing LED screen. In order to take out the screen you will have to unclamp areas lifting up the outer layer protecting the motherboard. This will lead to the release of digital ribbons connected from the to the motherboard.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Samsung DV180F Repair Display Screen Replacement, Display Screen: adım 1, 3 resimden 1. Samsung DV180F Repair Display Screen Replacement, Display Screen: adım 1, 3 resimden 2. Samsung DV180F Repair Display Screen Replacement, Display Screen: adım 1, 3 resimden 3.
    • Use a pry tool to push the highlighted blue latch away from the battery in the direction of the arrow. Remove the battery.
    • Use the Phillips 000 Bit to remove all screws from the perimeter of the device. Set aside.
    • Use a small Plastic Opening Tool at the seam by the Micro USB plug. Separate the plastic case from the device.
  2. Samsung DV180F Repair Display Screen Replacement: adım 2, 2 resimden 1. Samsung DV180F Repair Display Screen Replacement: adım 2, 2 resimden 2.
    • Remove the outer casing holding the back part of the camera together. Leave on the front casing.
    • Use a Phillips screwdriver to remove the two small screws holding the outer casing to the mother board.
    • Use the prying tool to unhook the casing from the plate covering the motherboard
  3. Samsung DV180F Repair Display Screen Replacement: adım 3, 3 resimden 1. Samsung DV180F Repair Display Screen Replacement: adım 3, 3 resimden 2. Samsung DV180F Repair Display Screen Replacement: adım 3, 3 resimden 3.
    • Release the ribbon from the button casing connected to the motherboard.
    • Hold the metal casing out of the way and snap the ribbon connector back. Remove the display screen ribbon attached.
    • Replace the screen then repeat all of these steps in reverse order to reassemble.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Gelecekteki Onarımlar İçin Hazırlanın
Hepsini satın al
Evan McGettrick
211 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 14-4, Eyestone Fall 2016 USF Tampa, Team 14-4, Eyestone Fall 2016 üyesi
USFT-EYESTONE-F16S14G4
4 Üyeler
8 adet Kılavuz yazıldı
2Kılavuz Yorumları
I got it open in the hope of finding a screen ID. I can not find a replacement screen for the DV180F. do you know if the DV150 screen will work?
lrrpbill68 - Yanıt
im looking for a screen as well were you able to find a replacement?
Sidath Paranavithane -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 27
Her zaman: 699
