Ana içeriğe geç
Samsung Epic 4G Micro USB Port Replacement
Neye ihtiyacın var
  1. Samsung Epic 4G Micro USB Port Replacement, Phone Case: adım 1, 1 resimden 1.
    • Slide your fingernail along the edge of the device and pull at the plastic backing.
    • While pulling the plastic backing apart from the device, you will hear a snap sound which signals that the backing has detached.
  2. Samsung Epic 4G Micro USB Port Replacement: adım 2, 1 resimden 1.
    • Pull at the plastic backing gently to remove it after hearing the snap sound.
  3. Samsung Epic 4G Micro USB Port Replacement, Battery: adım 3, 1 resimden 1.
    • Remove the battery from the device by pulling the battery edge upwards.
  4. Samsung Epic 4G Micro USB Port Replacement, Removing the Memory Card:: adım 4, 1 resimden 1.
    • Locate the memory card on the upper right-hand corner of the device.
    • Remove the memory card from the device by gently sliding it out of its holder with your fingers.
  5. Samsung Epic 4G Micro USB Port Replacement, Removing the Back Housing: adım 5, 2 resimden 1. Samsung Epic 4G Micro USB Port Replacement, Removing the Back Housing: adım 5, 2 resimden 2.
    • Remove the seven screws from the back of the phone using the Phillips #000 screwdriver.
    • Separate the backing from the silver trim around the phone by using a nylon spudger to pry between the two components.
    • While separating the two components, most of the buttons (including the power button) will fall out.
  6. Samsung Epic 4G Micro USB Port Replacement, Removing the Power Button: adım 6, 2 resimden 1. Samsung Epic 4G Micro USB Port Replacement, Removing the Power Button: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the power button using tweezers if it did not fall out in the previous step.
    • At this point, you can replace the power button with a new one from a manufacturer.
  7. Samsung Epic 4G Micro USB Port Replacement, Micro USB Port: adım 7, 1 resimden 1.
    • Remove the white cable along the right side of the device (next to the battery housing) using the nylon spudger.
    • Pull out both ends of the white cable. They will easily snap out of place without excessive tension.
    • Do not rip the white cables out of the device.
  8. Samsung Epic 4G Micro USB Port Replacement, Removing the Antenna Assembly: adım 8, 2 resimden 1. Samsung Epic 4G Micro USB Port Replacement, Removing the Antenna Assembly: adım 8, 2 resimden 2.
    • Remove the screw holding the antenna assembly in place using a Tri-Point Y0 screwdriver.
    • Snap the antenna assembly out of the device gently using your fingers.
  9. Samsung Epic 4G Micro USB Port Replacement, Removing the Flex Cable: adım 9, 2 resimden 1. Samsung Epic 4G Micro USB Port Replacement, Removing the Flex Cable: adım 9, 2 resimden 2.
    • Pry the flex cable from the top of the phone by carefully using a nylon spudger.
    • Repeat this step for the larger flex cable located on the left side of the device below the smaller one.
  10. Samsung Epic 4G Micro USB Port Replacement: adım 10, 1 resimden 1.
    • Lift and remove the motherboard from the device.
    • The USB port is located at the top of the motherboard. At this point, replace the port with a new one from a manufacturer.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Andrew Cunningham
273 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-25, Regan Fall 2012 Cal Poly, Team 24-25, Regan Fall 2012 üyesi
CPSU-REGAN-F12S24G25
4 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
My phone doesn’t have a memory card. At least, not that I can see. What should I do?
Joshua Campbell - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 2,376
