Ana içeriğe geç
Samsung Exhibit II 4G Display Assembly Replacement
Neye ihtiyacın var
  1. Samsung Exhibit II 4G Display Assembly Replacement, Battery: adım 1, 1 resimden 1.
    • Insert plastic opening tool under back cover.
    • Apply pressure on tool while using a downward motion to pop off back cover.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Exhibit II 4G Display Assembly Replacement: adım 2, 1 resimden 1.
    • Insert plastic opening tool under battery.
    • Pry battery out.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Exhibit II 4G Display Assembly Replacement, Top Rear Housing Cover: adım 3, 1 resimden 1.
    • Pry the top cover upward to remove it from the phone.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Exhibit II 4G Display Assembly Replacement: adım 4, 1 resimden 1.
    • Remove the top cover.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung Exhibit II 4G Display Assembly Replacement: adım 5, 2 resimden 1. Samsung Exhibit II 4G Display Assembly Replacement: adım 5, 2 resimden 2.
    • Remove the four 3.8mm Phillips #000 screws securing the top cover to the back assembly.
    • Two screws from top and two screws from back.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung Exhibit II 4G Display Assembly Replacement: adım 6, 3 resimden 1. Samsung Exhibit II 4G Display Assembly Replacement: adım 6, 3 resimden 2. Samsung Exhibit II 4G Display Assembly Replacement: adım 6, 3 resimden 3.
    • Insert plastic opening tool under top cover.
    • Using hand slide top cover away from phone.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung Exhibit II 4G Display Assembly Replacement, Midframe: adım 7, 1 resimden 1.
    • Remove the four 3.8mm Phillips #000 screws securing the back assembly to the phone.
    FixBot'a Sor
    Yorum Ekle
  8. Samsung Exhibit II 4G Display Assembly Replacement: adım 8, 1 resimden 1.
    • Insert plastic opening tool between back assembly and phone.
    • Pry the back assembly away from phone.
    FixBot'a Sor
    Yorum Ekle
  9. Samsung Exhibit II 4G Display Assembly Replacement: adım 9, 1 resimden 1.
    • With plastic opening tool continue prying around the edge of the back assembly.
    FixBot'a Sor
    Yorum Ekle
  10. Samsung Exhibit II 4G Display Assembly Replacement: adım 10, 1 resimden 1.
    • Pull back panel assembly away from main body.
    FixBot'a Sor
    Yorum Ekle
  11. Samsung Exhibit II 4G Display Assembly Replacement, Vibration Motor: adım 11, 2 resimden 1. Samsung Exhibit II 4G Display Assembly Replacement, Vibration Motor: adım 11, 2 resimden 2.
    • Insert the pointed end of a spudger into the gap in the round housing frame.
    • Using spudger to remove vibrator remove from the adhesive.
    FixBot'a Sor
    Yorum Ekle
  12. Samsung Exhibit II 4G Display Assembly Replacement: adım 12, 2 resimden 1. Samsung Exhibit II 4G Display Assembly Replacement: adım 12, 2 resimden 2.
    • Use the flat end of a spudger to remove vibrator cable from motherboard.
    FixBot'a Sor
    Yorum Ekle
  13. Samsung Exhibit II 4G Display Assembly Replacement, Rear Facing Camera: adım 13, 1 resimden 1.
    • Use the flat end of a spudger to disconnect the camera assembly cable.
    FixBot'a Sor
    Yorum Ekle
  14. Samsung Exhibit II 4G Display Assembly Replacement: adım 14, 2 resimden 1. Samsung Exhibit II 4G Display Assembly Replacement: adım 14, 2 resimden 2.
    • Remove camera from square housing.
    FixBot'a Sor
    Yorum Ekle
  15. Samsung Exhibit II 4G Display Assembly Replacement, Motherboard: adım 15, 3 resimden 1. Samsung Exhibit II 4G Display Assembly Replacement, Motherboard: adım 15, 3 resimden 2. Samsung Exhibit II 4G Display Assembly Replacement, Motherboard: adım 15, 3 resimden 3.
    • Insert the spudger under each corner ribbon cable and lift them out of the way.
    • Use care when lifting the ribbon cables.
    • Insert a plastic pry tool into the gap between motherboard and base of phone
    FixBot'a Sor
    Yorum Ekle
  16. Samsung Exhibit II 4G Display Assembly Replacement: adım 16, 3 resimden 1. Samsung Exhibit II 4G Display Assembly Replacement: adım 16, 3 resimden 2. Samsung Exhibit II 4G Display Assembly Replacement: adım 16, 3 resimden 3.
    • Tilt the motherboard up carefully.
    • Be sure not to damage the ribbon cable still connected at the bottom of the motherboard.
    • Use a spudger to pry the connector from the socket on the motherboard.
    • Lift motherboard from frame.
    FixBot'a Sor
    Yorum Ekle
  17. Samsung Exhibit II 4G Display Assembly Replacement, Headphone Jack: adım 17, 3 resimden 1. Samsung Exhibit II 4G Display Assembly Replacement, Headphone Jack: adım 17, 3 resimden 2. Samsung Exhibit II 4G Display Assembly Replacement, Headphone Jack: adım 17, 3 resimden 3.
    • Insert flat end of spudger between support panel and front assembly.
    • Using a spudger pry up to create opening to insert plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  18. Samsung Exhibit II 4G Display Assembly Replacement: adım 18, 2 resimden 1. Samsung Exhibit II 4G Display Assembly Replacement: adım 18, 2 resimden 2.
    • Insert a plactic opening tool in opening.
    • Use plastic opening tool to pry around the edge of support panel to free it from front assembly.
    FixBot'a Sor
    Yorum Ekle
  19. Samsung Exhibit II 4G Display Assembly Replacement: adım 19, 3 resimden 1. Samsung Exhibit II 4G Display Assembly Replacement: adım 19, 3 resimden 2. Samsung Exhibit II 4G Display Assembly Replacement: adım 19, 3 resimden 3.
    • Insert the pointed end of a spudger into gap.
    • Lift spudger away from support plate to remove headphone component.
    FixBot'a Sor
    Yorum Ekle
  20. Samsung Exhibit II 4G Display Assembly Replacement: adım 20, 3 resimden 1. Samsung Exhibit II 4G Display Assembly Replacement: adım 20, 3 resimden 2. Samsung Exhibit II 4G Display Assembly Replacement: adım 20, 3 resimden 3.
    • Use the flat end of the spudger to remove headphone jack component from rectangular housing.
    FixBot'a Sor
    Yorum Ekle
  21. Samsung Exhibit II 4G Display Assembly Replacement, Display Assembly: adım 21, 3 resimden 1. Samsung Exhibit II 4G Display Assembly Replacement, Display Assembly: adım 21, 3 resimden 2. Samsung Exhibit II 4G Display Assembly Replacement, Display Assembly: adım 21, 3 resimden 3.
    • The the flat end of a spudger between componet and frame.
    • Use the the spudger to lift the componet from the frame.
    FixBot'a Sor
    Yorum Ekle
  22. Samsung Exhibit II 4G Display Assembly Replacement: adım 22, 3 resimden 1. Samsung Exhibit II 4G Display Assembly Replacement: adım 22, 3 resimden 2. Samsung Exhibit II 4G Display Assembly Replacement: adım 22, 3 resimden 3.
    • Insert the spudger between blue flim and the back of the LCD.
    • Using the spudger lift blue film away from LCD.
    FixBot'a Sor
    Yorum Ekle
  23. Samsung Exhibit II 4G Display Assembly Replacement: adım 23, 3 resimden 1. Samsung Exhibit II 4G Display Assembly Replacement: adım 23, 3 resimden 2. Samsung Exhibit II 4G Display Assembly Replacement: adım 23, 3 resimden 3.
    • Notice ribbon cable slides under the tan square component.
    FixBot'a Sor
    Yorum Ekle
  24. Samsung Exhibit II 4G Display Assembly Replacement: adım 24, 3 resimden 1. Samsung Exhibit II 4G Display Assembly Replacement: adım 24, 3 resimden 2. Samsung Exhibit II 4G Display Assembly Replacement: adım 24, 3 resimden 3.
    • Insert a plastic opening tool between LCD and Digitizer screen.
    • Use plastic opening tool to pry and lift the LCD from the glass screen.
    • Adhesive material around edge of LCD.
    FixBot'a Sor
    Yorum Ekle
  25. Samsung Exhibit II 4G Display Assembly Replacement: adım 25, 2 resimden 1. Samsung Exhibit II 4G Display Assembly Replacement: adım 25, 2 resimden 2.
    • Lift LCD away from digitizer screen.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
David R
1.152 İtibar
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 13
Her zaman: 1,101
