Giriş
Use this guide to replace a cracked Touch Screen / Digitizer or LCD.
Neye ihtiyacın var
Insert plastic opening tool under back cover.
Apply pressure on tool while using a downward motion to pop off back cover.
Pry the top cover upward to remove it from the phone.
Remove the four 3.8mm Phillips #000 screws securing the back assembly to the phone.
Insert the pointed end of a spudger into the gap in the round housing frame.
Using spudger to remove vibrator remove from the adhesive.
Use the flat end of a spudger to disconnect the camera assembly cable.
Insert the spudger under each corner ribbon cable and lift them out of the way.
Insert a plastic pry tool into the gap between motherboard and base of phone
Insert flat end of spudger between support panel and front assembly.
Using a spudger pry up to create opening to insert plastic opening tool.
The the flat end of a spudger between componet and frame.
Use the the spudger to lift the componet from the frame.
3 farklı kişi bu kılavuzu tamamladı.
