Giriş
Use this guide to replace a defective Camera.
Neye ihtiyacın var
Insert plastic opening tool under back cover.
Apply pressure on tool while using a downward motion to pop off back cover.
Pry the top cover upward to remove it from the phone.
Remove the four 3.8mm Phillips #000 screws securing the back assembly to the phone.
Use the flat end of a spudger to disconnect the camera assembly cable.
Bir başkası bu kılavuzu tamamladı.
