Ana içeriğe geç
Samsung Exhibit II 4G Vibration Motor Replacement
Neye ihtiyacın var
  1. Samsung Exhibit II 4G Vibration Motor Replacement, Battery: adım 1, 1 resimden 1.
    • Insert plastic opening tool under back cover.
    • Apply pressure on tool while using a downward motion to pop off back cover.
  2. Samsung Exhibit II 4G Vibration Motor Replacement: adım 2, 1 resimden 1.
    • Insert plastic opening tool under battery.
    • Pry battery out.
  3. Samsung Exhibit II 4G Vibration Motor Replacement, Top Rear Housing Cover: adım 3, 1 resimden 1.
    • Pry the top cover upward to remove it from the phone.
  4. Samsung Exhibit II 4G Vibration Motor Replacement: adım 4, 1 resimden 1.
    • Remove the top cover.
  5. Samsung Exhibit II 4G Vibration Motor Replacement: adım 5, 2 resimden 1. Samsung Exhibit II 4G Vibration Motor Replacement: adım 5, 2 resimden 2.
    • Remove the four 3.8mm Phillips #000 screws securing the top cover to the back assembly.
    • Two screws from top and two screws from back.
  6. Samsung Exhibit II 4G Vibration Motor Replacement: adım 6, 3 resimden 1. Samsung Exhibit II 4G Vibration Motor Replacement: adım 6, 3 resimden 2. Samsung Exhibit II 4G Vibration Motor Replacement: adım 6, 3 resimden 3.
    • Insert plastic opening tool under top cover.
    • Using hand slide top cover away from phone.
  7. Samsung Exhibit II 4G Vibration Motor Replacement, Midframe: adım 7, 1 resimden 1.
    • Remove the four 3.8mm Phillips #000 screws securing the back assembly to the phone.
  8. Samsung Exhibit II 4G Vibration Motor Replacement: adım 8, 1 resimden 1.
    • Insert plastic opening tool between back assembly and phone.
    • Pry the back assembly away from phone.
  9. Samsung Exhibit II 4G Vibration Motor Replacement: adım 9, 1 resimden 1.
    • With plastic opening tool continue prying around the edge of the back assembly.
  10. Samsung Exhibit II 4G Vibration Motor Replacement: adım 10, 1 resimden 1.
    • Pull back panel assembly away from main body.
  11. Samsung Exhibit II 4G Vibration Motor Replacement, Vibration Motor: adım 11, 2 resimden 1. Samsung Exhibit II 4G Vibration Motor Replacement, Vibration Motor: adım 11, 2 resimden 2.
    • Insert the pointed end of a spudger into the gap in the round housing frame.
    • Using spudger to remove vibrator remove from the adhesive.
  12. Samsung Exhibit II 4G Vibration Motor Replacement: adım 12, 2 resimden 1. Samsung Exhibit II 4G Vibration Motor Replacement: adım 12, 2 resimden 2.
    • Use the flat end of a spudger to remove vibrator cable from motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
David R
1.152 İtibar
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 380
