Ana içeriğe geç
Samsung Galaxy A50 Display Assembly with Frame Replacement
ZFix
ZFix ve başka bir katkıda bulunan
En son September 12, 2023 tarihinde güncellendi
45 dakika
Orta
Topluluk-Katkılı Kılavuz
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
Videoya Genel Bakış
  1. Samsung Galaxy A50 Display Assembly with Frame Replacement, LCD Display Assembly replacement: adım 1, 3 resimden 1. Samsung Galaxy A50 Display Assembly with Frame Replacement, LCD Display Assembly replacement: adım 1, 3 resimden 2. Samsung Galaxy A50 Display Assembly with Frame Replacement, LCD Display Assembly replacement: adım 1, 3 resimden 3.
    • Display Touch Screen Digitizer Assembly with Frame for Samsung Galaxy A50
  2. Samsung Galaxy A50 Display Assembly with Frame Replacement, Battery cover removal: adım 2, 3 resimden 1. Samsung Galaxy A50 Display Assembly with Frame Replacement, Battery cover removal: adım 2, 3 resimden 2. Samsung Galaxy A50 Display Assembly with Frame Replacement, Battery cover removal: adım 2, 3 resimden 3.
    • Heat up the back cover to loosen the adhesive.
    • To separate the back cover use a Suction Cup and plastic tools.
  3. Samsung Galaxy A50 Display Assembly with Frame Replacement, Middle frame removal: adım 3, 3 resimden 1. Samsung Galaxy A50 Display Assembly with Frame Replacement, Middle frame removal: adım 3, 3 resimden 2. Samsung Galaxy A50 Display Assembly with Frame Replacement, Middle frame removal: adım 3, 3 resimden 3.
    • Remove the SIM tray.
    • Remove the Philips Screws.
    • Again use plastic tools to separate the middle frame.
  4. Samsung Galaxy A50 Display Assembly with Frame Replacement, Test the new spare part: adım 4, 3 resimden 1. Samsung Galaxy A50 Display Assembly with Frame Replacement, Test the new spare part: adım 4, 3 resimden 2. Samsung Galaxy A50 Display Assembly with Frame Replacement, Test the new spare part: adım 4, 3 resimden 3.
    • First disconnect the Battery.
    • Test the new spare part before the installation.
  5. Samsung Galaxy A50 Display Assembly with Frame Replacement, Logic board removal: adım 5, 3 resimden 1. Samsung Galaxy A50 Display Assembly with Frame Replacement, Logic board removal: adım 5, 3 resimden 2. Samsung Galaxy A50 Display Assembly with Frame Replacement, Logic board removal: adım 5, 3 resimden 3.
    • Disconnect and remove the Main Flex Cable.
    • Remove the black Philips screw, it's shorter then the middle frame screws.
    • Disconnect the coaxial antenna cable.
    • Now you can remove the logic board.
  6. Samsung Galaxy A50 Display Assembly with Frame Replacement, Sub board removal: adım 6, 3 resimden 1. Samsung Galaxy A50 Display Assembly with Frame Replacement, Sub board removal: adım 6, 3 resimden 2. Samsung Galaxy A50 Display Assembly with Frame Replacement, Sub board removal: adım 6, 3 resimden 3.
    • First remove the Fingerprint sensor.
    • The screws for the Fingerprint are shorter.
    • It's better to use hot air before to disassemble the sub-board.
    • Reminder - only plastic tools :)
  7. Samsung Galaxy A50 Display Assembly with Frame Replacement, Battery removal: adım 7, 3 resimden 1. Samsung Galaxy A50 Display Assembly with Frame Replacement, Battery removal: adım 7, 3 resimden 2. Samsung Galaxy A50 Display Assembly with Frame Replacement, Battery removal: adım 7, 3 resimden 3.
    • Again, hot air, plastic tools and very slowly remove the battery.
  8. Samsung Galaxy A50 Display Assembly with Frame Replacement: adım 8, 1 resimden 1.
    • All's Well That Ends Well
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
ZFix
194.325 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
327 Üyeler
1.677 adet Kılavuz yazıldı
2Kılavuz Yorumları
The frame I bought doesn't have the place for earspeaker surrounded by little "walls", so it's very loose and doesn't have contact with the board. Anyone experienced this?
knezi - Yanıt
You can just use small amount of jelly glue to attach it to the frame it'll work fine as long its stay in a right place the logic board will help it keep it in place
Zent -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 42
Son 30 gün: 213
Her zaman: 16,850
