Ana içeriğe geç
Samsung Galaxy Buds Battery Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Buds Battery Replacement, Battery: adım 1, 3 resimden 1. Samsung Galaxy Buds Battery Replacement, Battery: adım 1, 3 resimden 2. Samsung Galaxy Buds Battery Replacement, Battery: adım 1, 3 resimden 3.
    • If possible, drain the battery in your Galaxy Buds before performing a battery replacement.
    • Begin by taking off the earbud's rubber wingtip:
    • Grab the tip (where the "R" label is) and gently pull upward on it while slipping it off the bud.
  2. Samsung Galaxy Buds Battery Replacement, Opening up the earbud: adım 2, 3 resimden 1. Samsung Galaxy Buds Battery Replacement, Opening up the earbud: adım 2, 3 resimden 2. Samsung Galaxy Buds Battery Replacement, Opening up the earbud: adım 2, 3 resimden 3.
    • Place the bud horizontally into a rubber-guarded vice or a pair of blunt pliers.
    • Apply steady, even pressure to either side of the bud along the main housing seam (the seam between the two arrows). The pressure should break the seal.
    • Only apply enough pressure to create a small gap between the two halves of the bud. If you use pliers, put a cloth between the pliers and the buds to prevent the teeth from digging into the soft plastic.
  3. Samsung Galaxy Buds Battery Replacement: adım 3, 3 resimden 1. Samsung Galaxy Buds Battery Replacement: adım 3, 3 resimden 2. Samsung Galaxy Buds Battery Replacement: adım 3, 3 resimden 3.
    • Once you have created a gap between the two halves of the bud, gently pry them apart with a plastic opening tool.
    • You may need to work your way around the entire earbud with the opening tool. Take your time and do your best not to deform the plastic.
    • Carefully remove the top half of the bud.
    • Be careful when pulling the halves apart! Sometimes the battery assembly gets caught in the case. If the top half of your case doesn't come out cleanly, skip this step and disconnect the cable in step 4 before separating the two halves of the bud.
    • During reassembly, line up the arrows on the two halves of the outer case, then press the halves together until they snap into place.
  4. Samsung Galaxy Buds Battery Replacement: adım 4, 3 resimden 1. Samsung Galaxy Buds Battery Replacement: adım 4, 3 resimden 2. Samsung Galaxy Buds Battery Replacement: adım 4, 3 resimden 3.
    • Use a spudger to lift up and disconnect the press connector connecting the battery/board assembly to the speaker drivers and the other sensors in the case.
    • Once the cable is disconnected, remove the assembly from the bud.
    • During reassembly, slide battery/board assembly into the earbud so that the peg from the outer case fits into the notch in the battery housing. Then reattach the connector to reconnect the assembly.
  5. Samsung Galaxy Buds Battery Replacement: adım 5, 3 resimden 1. Samsung Galaxy Buds Battery Replacement: adım 5, 3 resimden 2. Samsung Galaxy Buds Battery Replacement: adım 5, 3 resimden 3.
    • The remaining components are held together with clips and light adhesive. Work carefully, stay organized, and don't tug on anything too hard.
    • Pry up and remove the plastic cap from the bottom of the battery/board assembly.
  6. Samsung Galaxy Buds Battery Replacement: adım 6, 2 resimden 1. Samsung Galaxy Buds Battery Replacement: adım 6, 2 resimden 2.
    • The motherboard consists of two boards wrapped around the battery housing, connected by a flex cable.
    • Use an opening tool to gently pry up one of the boards along its edge, away from the flex cable.
  7. Samsung Galaxy Buds Battery Replacement: adım 7, 3 resimden 1. Samsung Galaxy Buds Battery Replacement: adım 7, 3 resimden 2. Samsung Galaxy Buds Battery Replacement: adım 7, 3 resimden 3.
  8. Samsung Galaxy Buds Battery Replacement: adım 8, 2 resimden 1. Samsung Galaxy Buds Battery Replacement: adım 8, 2 resimden 2.
    • Use a plastic opening tool to pry up and remove the crescent-shaped cap on the top side of the battery housing.
  9. Samsung Galaxy Buds Battery Replacement, Removing the battery: adım 9, 3 resimden 1. Samsung Galaxy Buds Battery Replacement, Removing the battery: adım 9, 3 resimden 2. Samsung Galaxy Buds Battery Replacement, Removing the battery: adım 9, 3 resimden 3.
    • The bottom of the battery housing has holes, which allow you to push the battery out. The flat side of a spudger fits perfectly through the widest opening, marked here in red.
    • Insert the flat end of a spudger (or another plastic prying tool) into the bottom of the battery housing and push the battery out the other side.
  10. Samsung Galaxy Buds Battery Replacement: adım 10, 1 resimden 1.
    • Remove the battery from the battery housing.
    • If possible, transfer the foam strips from the original Galaxy Buds battery to your new one. The foam helps to prevent contact between the battery and other bits inside the bud, and also keeps the battery from moving around inside the housing.
Sonuç
To reassemble your device, follow the above steps in reverse order. Use Tesa tape to re-adhere parts that won’t re-adhere with the residual original adhesive.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted back to 100%.
Repair didn’t go as planned? Check out our Galaxy Buds Answers community for troubleshooting help.
38 farklı kişi bu kılavuzu tamamladı.
Nick Galardi
421 İtibar
1 Kılavuz yazıldı
20 Yorum
How to fix not working mic on my galaxy bud
angelofgod jesus's - Yanıt
Requiere un cambio de pieza electronica correspondiente al microfono, ya que pudo haberse mojado
Pena Ernesto -
My Galaxy buds had the newer CP1254 A3 battery. My Buds were purchased new in August 2019.
Adrian Tolano - Yanıt
My earbuds touchpad is not working after take shower , can you help how can i repair it
Mohsen Hosseini - Yanıt
Can this battery replacement be done on the new Galaxy Bud+?
Ed Martin - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 47
Son 7 gün: 322
Son 30 gün: 1,697
Her zaman: 125,764
