Giriş
This guide teaches you how to replace the flash in your camera. If the flash isn't staying open or the flashbulb is burnt out, replacing this piece may be the solution to your troubles. Always make sure to remove the battery before attempting any repairs!
Neye ihtiyacın var
While holding the camera, take note of each screw holding the screen to the main chassis of the camera.
Hold the camera upright and lens facing towards you. There area total of six 4mm PH00 screws to undo - two on the left, one screw on the right, and three along the bottom. Two of them are hidden behind the battery compartment door.
With the screws removed, use the plastic opening tool to gently pry the screen away from the main camera chassis. The ideal spot to start is at the corner with the headphone jack, as indicated in the picture.
Once this side is free, gently work your way along the edge, all the way around the camera body.
Set the body aside in a safe place.
After removing the screen and battery to access to the inside of the camera, take note of the two main assemblies inside-- the lens apparatus and the main motherboard. The lens assembly is on the left hand side.
There are three small silver screws (4mm PH00) to remove.
Bu adımda kullanılan alet:Tweezers$4.99
With the three screws removed, take note of the two ribbon cables connecting the lens assembly to the main motherboard.
Use the tweezers to remove the two green strips of tape protecting the connectors.
Use the plastic opening tool to release the black clips locking in the ribbon cables, then use the tweezers to gently pull the ribbon cables away from the main motherboard.
Now that the screws and ribbon cables have been removed, gently pull the lens assembly up from the the camera and remove it.
Zoom error
not work?
How fix?
The instructions were perfect. Great pictures and step-by-step instruction. Great
Now that you've removed the battery, screen, and lens assembly, you are ready to continue inremoving the motherboard.
There are small ribbon cables connected to the motherboard. Use your plastic opening tool and gently pry the sides of the connectors away from the motherboard. Tuck them away to prevent damaging them when removing the motherboard.
After removing the ribbon cables, take note of the screws holding the motherboard into the main chassis of the camera.
There are two types of screws to remove. The four (2mm, PH00) circled in red have a fat head, and go in the gold contact.
The three (4mm, PH00) screws marked in green have a skinny head.
Use the IFIXIT screwdriver and PH0 bit to remove all the screws holding the motherboard.
With all the screws removed, use the plastic opening tool to gently pry the headphone jack away from its casing. That jack holds the motherboard in place.
Next, gently slide the plastic opening tool underneath the motherboard. Move your fingers underneath and use your hands to completely remove it.
Now, remove the motherboard completely from the chassis.
IF I hear the camera come on but the screen doesn't light up and I cant take pix, is it the screen, a connection or the motherboard. It stopped taking pix In the middle of me taking pictures of my son …. I just thought it died. my husband tested the battery and it was charged, so I know it’s something internal. HELP!!!!! I feel lost w/out my camera :(
Underneath the motherboard, there is a thin metal plate. This plate should lift up easily, as there are no screws keeping it in place.
Before you can take out the black frame, make sure to remove the silver accents on the casing. Use the plastic opening tool to gently pry them off.
Although not necessary, it is advisable to remove the silver cover from the flash. Take out the two screws holding it together and gently pop off the top with the plastic opening tool. We chose to put it back on for the rest of the guide to add stability to the piece.
6 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
Hi! Where can i buy this samsung galaxy camera 2 flash unit?
hi where can i get samsung galaxy camera 2 flash light
