Ana içeriğe geç
Samsung Galaxy Luna LCD display Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Luna LCD display Replacement, LCD display: adım 1, 1 resimden 1.
    • Attach a small suction cup to the lower half of the glass screen.
  2. Samsung Galaxy Luna LCD display Replacement: adım 2, 1 resimden 1.
    • Apply pressure to the middle section of the screen while pulling up the lower edge by pivoting your wrist.
  3. Samsung Galaxy Luna LCD display Replacement: adım 3, 1 resimden 1.
    • Once you've opened a large enough gap, insert a Spudger tool between the glass and the motherboard.
    • Slide the Spudger tool around the gap until the screen is completely separated from the motherboard.
    • The LCD is very fragile,be careful when sliding the spudger around the gap.
  4. Samsung Galaxy Luna LCD display Replacement: adım 4, 2 resimden 1. Samsung Galaxy Luna LCD display Replacement: adım 4, 2 resimden 2.
    • Pull the rear panel up and away to completely separate it.
    • make sure the panel is completely detached from the phone frame before separating it.
  5. Samsung Galaxy Luna LCD display Replacement: adım 5, 3 resimden 1. Samsung Galaxy Luna LCD display Replacement: adım 5, 3 resimden 2. Samsung Galaxy Luna LCD display Replacement: adım 5, 3 resimden 3.
    • Place the spudger tool between the LCD and the glass screen.
    • Slide the spudger tool in between the screen and the display until both are completely separated from each other.
    • The LCD is very fragile, do not apply excessive force when prying the glass panel
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
xingyu chen
266 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S6-G1, Eyestone Spring 2018 USF Tampa, Team S6-G1, Eyestone Spring 2018 üyesi
USFT-EYESTONE-S18S6G1
4 Üyeler
5 adet Kılavuz yazıldı
2Kılavuz Yorumları
Hola, cual es el numero de parte de la pantalla a reemplazar?
Luis A. Andueza - Yanıt
It appears that OEM screens are no longer available for this phone. I was able to find this third party display assembly that looks like it would work, but I can’t attest to its functionality, so there would be a bit of risk involved for you. Hope that helps!
Austin Blakely -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 17
Her zaman: 1,124
