Ana içeriğe geç
Samsung Galaxy Mega Display Assembly Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Mega Display Assembly Replacement, Remove Rear Cover: adım 1, 2 resimden 1. Samsung Galaxy Mega Display Assembly Replacement, Remove Rear Cover: adım 1, 2 resimden 2.
    • Use the opening tool or a fingernail to pry open the rear cover at the top left corner.
    • Once the rear cover is removed, you'll have access to the SIM card, the SD card, and screws.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Galaxy Mega Display Assembly Replacement, SIM, SD, Screw and Battery Removal: adım 2, 3 resimden 1. Samsung Galaxy Mega Display Assembly Replacement, SIM, SD, Screw and Battery Removal: adım 2, 3 resimden 2. Samsung Galaxy Mega Display Assembly Replacement, SIM, SD, Screw and Battery Removal: adım 2, 3 resimden 3.
    • After removing the back cover, remove the battery, the SIM card, and SD card (if present).
    • Remove the highlighted PH000 screws from the rear of the phone.
    • Ensure the phone has been powered down via the OS (if possible) before removing the battery.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Galaxy Mega Display Assembly Replacement, Speaker Removal: adım 3, 1 resimden 1.
    • Using the opening tool, gently pry the speaker upwards and remove it.
    • The speaker is fragile; take caution when removing it to prevent damage.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Galaxy Mega Display Assembly Replacement, Removal of Back Frame: adım 4, 3 resimden 1. Samsung Galaxy Mega Display Assembly Replacement, Removal of Back Frame: adım 4, 3 resimden 2. Samsung Galaxy Mega Display Assembly Replacement, Removal of Back Frame: adım 4, 3 resimden 3.
    • Insert the pry tool along the side of the device. Pry gently until you hear clicks.
    • Repeat along all sides of the phone. You will continue hearing a clicking sound as the frame begins to release.
    • Gently pull the battery clip up (shown in photo 2). Then, twist the frame slightly clockwise, as there is a little clip around the camera that needs to be released.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung Galaxy Mega Display Assembly Replacement, Removing Ribbons: adım 5, 2 resimden 1. Samsung Galaxy Mega Display Assembly Replacement, Removing Ribbons: adım 5, 2 resimden 2.
    • Use the opening tool to remove the LCD cable.
    • Once the back frame has been removed, the motherboard and connectors will be exposed.
    • Remove the front camera by unscrewing the panel.
    • Disconnect the front camera cable.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung Galaxy Mega Display Assembly Replacement, Adding some heat: adım 6, 3 resimden 1. Samsung Galaxy Mega Display Assembly Replacement, Adding some heat: adım 6, 3 resimden 2. Samsung Galaxy Mega Display Assembly Replacement, Adding some heat: adım 6, 3 resimden 3.
    • Use the heat gun to heat around the edges of the screen.
    • Insert three opening picks between the glass and the silver frame of the phone to pry it open.
    • Do not insert a pick at the bottom of the screen. The back button and the menu button break easily.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung Galaxy Mega Display Assembly Replacement, Removing screen: adım 7, 3 resimden 1. Samsung Galaxy Mega Display Assembly Replacement, Removing screen: adım 7, 3 resimden 2. Samsung Galaxy Mega Display Assembly Replacement, Removing screen: adım 7, 3 resimden 3.
    • With the opening picks still inside the phone, lift the screen up toward you. Do not pull it off right away, but leave the screen at an angle.
    • Put the screen down along with the opening picks in order to keep it loose. Heat up the bottom to loosen the adhesive from the back and the menu button.
    • Carefully pull the screen towards you. Keep an eye on the bottom to make sure that the buttons are separating from the adhesive.
    • Be very careful when removing the button flex cables from the screen. If these cables are broken, you will need to replace the charging port assembly.
    FixBot'a Sor
    Yorum Ekle
  8. Samsung Galaxy Mega Display Assembly Replacement, Final step screen is off: adım 8, 3 resimden 1. Samsung Galaxy Mega Display Assembly Replacement, Final step screen is off: adım 8, 3 resimden 2. Samsung Galaxy Mega Display Assembly Replacement, Final step screen is off: adım 8, 3 resimden 3.
    • Verify that the buttons are completely separated from the adhesive.
    • Separate the screen from the bezel.
    FixBot'a Sor
    Yorum Ekle
Sonuç
46 farklı kişi bu kılavuzu tamamladı.
3Kılavuz Yorumları
replaced screen everything works fine excepe want pickup network .this was a unlocked phone is there any way replacing it would lock it up again
KENNETH P - Yanıt Paylaş
Unless you replaced the board, I can't see how. You might have left something disconnected.
Rongwey - Yanıt Paylaş
check your antenna cable connection, it will not pick up a signal if not connected
Ron Lindon - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 17
Son 30 gün: 73
Her zaman: 19,979
