Ana içeriğe geç
Samsung Galaxy Note 3 Display Assembly Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Note 3 Display Assembly Replacement, Remove the rear case: adım 1, 1 resimden 1.
    • Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
  2. Samsung Galaxy Note 3 Display Assembly Replacement, Remove Case from the Base: adım 2, 2 resimden 1. Samsung Galaxy Note 3 Display Assembly Replacement, Remove Case from the Base: adım 2, 2 resimden 2.
    • Slide your fingernail or plastic opening tool along the edge of the rear case.
    • Lift the case gently from the base.
    Why... is it not simple enough already lol
    Adam Ahmed - Yanıt
  3. Samsung Galaxy Note 3 Display Assembly Replacement, Battery: adım 3, 2 resimden 1. Samsung Galaxy Note 3 Display Assembly Replacement, Battery: adım 3, 2 resimden 2.
    • Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base.
    • Lift the battery out of its recess.
  4. Samsung Galaxy Note 3 Display Assembly Replacement, S Pen: adım 4, 1 resimden 1.
    • Place your fingernail in the groove of the stylus pen.
    • Pull the stylus pen away from the phone.
  5. Samsung Galaxy Note 3 Display Assembly Replacement, Unscrew Back Chassis: adım 5, 1 resimden 1.
    • Remove the twelve 4mm Phillips #00 screws from the back chassis.
  6. Samsung Galaxy Note 3 Display Assembly Replacement, Remove Back Chassis: adım 6, 1 resimden 1.
    • Insert the plastic opening tool into the Stylus Pen placement holder.
    • Lift the plastic opening tool so that the midframe separates from the base.
  7. Samsung Galaxy Note 3 Display Assembly Replacement, Screw Removal: adım 7, 2 resimden 1. Samsung Galaxy Note 3 Display Assembly Replacement, Screw Removal: adım 7, 2 resimden 2.
    • Remove the single screw beside headphone jack.
    You can skip this step, it is usseles as this screw doesn’t attach the mother board at all
    Oriol Felisart - Yanıt
  8. Samsung Galaxy Note 3 Display Assembly Replacement, Unfasten Clips and Cable Connectors: adım 8, 2 resimden 1. Samsung Galaxy Note 3 Display Assembly Replacement, Unfasten Clips and Cable Connectors: adım 8, 2 resimden 2.
    • Use tweezers to remove both antenna clips.
    • Use a spudger to disconnect six cable connectors.
  9. Samsung Galaxy Note 3 Display Assembly Replacement, Motherboard Removal: adım 9, 1 resimden 1.
    • Pull up on the motherboard with tweezers.
    Can i change at&t board to 9002 or 9005??,
    Ayyaz - Yanıt
    My mother board is not working what should I do I can't use Bluetooth, WiFi,hotspot or insert sim
    soha Javed - Yanıt
    My wifi hotspot is not working
    Kiran Thopate - Yanıt
  10. Samsung Galaxy Note 3 Display Assembly Replacement, Spudger Tool Placement: adım 10, 1 resimden 1.
    • Insert the spudger into the headphone jack.
  11. Samsung Galaxy Note 3 Display Assembly Replacement, Lift to Separate Headphone Jack: adım 11, 1 resimden 1.
    • Lift the spudger to separate the jack assembly from the motherboard.
    • Pull to remove.
    it remove the jack and the speaker in the same time.
    bangahome - Yanıt
  12. Samsung Galaxy Note 3 Display Assembly Replacement, Metal Bracket Removal: adım 12, 1 resimden 1.
    • Remove the metal bracket located in the top left hand corner.
    As well as the front camera and sensor up under it.
    Xavier Rodriguez - Yanıt
  13. Samsung Galaxy Note 3 Display Assembly Replacement, Remove Vibrating Motor: adım 13, 1 resimden 1.
    • Remove the vibrating motor by pulling up on it carefully with the tweezers.
    toggle the motor on the left, cause you need to remove the start button with the motor in the same time.
    All is paste on the display assembly. Use a screw to pass under the elements, and unglue them.
    bangahome - Yanıt
  14. Samsung Galaxy Note 3 Display Assembly Replacement, USB Port Removal: adım 14, 1 resimden 1.
    • Lift USB port from the front assembly using the tweezers.
    You need to pull up the USB port and all the blue card.
    Use a screw to pass under the card, beacause everything is paste on the display assembly.
    bangahome - Yanıt
    Be VERY careful with the board, or just leave it there.
    In some (I think all) devices, the board is GLUED with the display assembly.
    Maybe to stabilize the port (But they can use screws, right? D*mn nasty glue!).
    Salvator - Yanıt
  15. Samsung Galaxy Note 3 Display Assembly Replacement, Display Assembly: adım 15, 1 resimden 1.
    • You are now left with the display assembly.
    Wonderful description.
    matha studio - Yanıt
    It tooks me about an hour to change the display.
    Thanks for this tutorial.
    bangahome - Yanıt
Sonuç
146 farklı kişi bu kılavuzu tamamladı.
Brittany Gail
8.504 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-2, Blackwell Fall 2014 USF Tampa, Team 2-2, Blackwell Fall 2014 üyesi
USFT-BLACKWELL-F14S2G2
4 Üyeler
25 adet Kılavuz yazıldı
10 Yorum
είναι απόλυτα κατανοητό.
chandr - Yanıt
Can you just replace the digitizer or is the digitizer glue down to good to the display where it might damage the LCD display when trying to replace the digitizer?
rob lang - Yanıt
to safely remove the LCD display from the front touch screen glass w/o damaging the LCD screen I advise you to invest in and familiarize yourself with an LCD Separator machine and all the accessories that go along with it. Also, search for the machine and watch the videos..
tkflenorl - Yanıt
sunil - Yanıt
Can you just replace the digitizer or is the digitizer glue down to good to the display where it might damage the LCD display when trying to replace touch
sunil - Yanıt
This tutorial is incomplete, for instance the 'vibrator motor' removal does not specifies that this also removes the power button, and the removal of the front camera and light sensor is omitted, and the fact that heating the usb port part is very helpful if not mandatory before lifting it. I followed the video tutorial here which is complete: Samsung Galaxy Note 3 Display Assembly Video Tutorial Replacement
Julien GENEST - Yanıt
How do I remove the screen/digitizer/front glass from the display assembly? I have a broken screen and need to install the replacement LCD/digitizer piece I bought, and need to install it into the display assembly before reassembling.
David H - Yanıt
How I can replace the wifi and bluetooth part in note?
mohanad - Yanıt
warning :
on the new part (display assembly) don’t forget to remove plastic protection on the radiator of cpu !!
Michel BERNARD - Yanıt
I have successfully replaced the display with a new display, at which point the power button wasn’t working properly because I didn’t install it properly - fixed that, and I have now noticed that the phone will charge with the back plate on, only, however if I screw the back plate in this stops it from charging. What am I doing wrong?
Jesse - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 18
Son 30 gün: 71
Her zaman: 122,299
