Ana içeriğe geç
Samsung Galaxy Note Antenna Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. Samsung Galaxy Note Antenna Replacement, Battery: adım 1, 3 resimden 1. Samsung Galaxy Note Antenna Replacement, Battery: adım 1, 3 resimden 2. Samsung Galaxy Note Antenna Replacement, Battery: adım 1, 3 resimden 3.
    • Make sure the screen is face-down and the camera is opposite you.
    • Insert the flat end of a spudger into the phone's top right rectangular slot.
    • Use the spudger as a lever to pry open the back of the phone.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Galaxy Note Antenna Replacement: adım 2, 1 resimden 1.
    • With the spudger still inserted, carefully slide the spudger down the side of the phone.
    • Gently peel off the back cover with your hand.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Galaxy Note Antenna Replacement: adım 3, 1 resimden 1.
    • Place the spudger in the battery's bottom right slot.
    • Gently pry to remove the battery.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Galaxy Note Antenna Replacement, Midframe: adım 4, 1 resimden 1.
    • Remove the nine 3mm screws on the perimeter of the phone with a Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung Galaxy Note Antenna Replacement: adım 5, 1 resimden 1.
    • Remove the stylus from the bottom of the phone.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung Galaxy Note Antenna Replacement: adım 6, 3 resimden 1. Samsung Galaxy Note Antenna Replacement: adım 6, 3 resimden 2. Samsung Galaxy Note Antenna Replacement: adım 6, 3 resimden 3.
    • Pry all the way around the sides with a plastic pry tool and gently pop off the midframe.
    • If the cover does not come off easily, continue to pry along the phone's perimeter.
    • This step can take some patience. Prying too hard or forcing the screen off can crack or scratch the screen and break the thin plastic around the stylus case.
    • Separate the midframe from the phone. The midframe should now pull off easily.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung Galaxy Note Antenna Replacement, Antenna: adım 7, 1 resimden 1.
    • Remove the two 3mm screws surrounded by a gold border with a Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  8. Samsung Galaxy Note Antenna Replacement: adım 8, 2 resimden 1. Samsung Galaxy Note Antenna Replacement: adım 8, 2 resimden 2.
    • Use the spudger to pry up all six flex ribbons that hold the motherboard in place. They should pop off easily.
    FixBot'a Sor
    Yorum Ekle
  9. Samsung Galaxy Note Antenna Replacement: adım 9, 1 resimden 1.
    • Use the spudger to pull off the white wire with the gold connector.
    FixBot'a Sor
    Yorum Ekle
  10. Samsung Galaxy Note Antenna Replacement: adım 10, 1 resimden 1.
    • Lift the motherboard (PCB) directly up with your hands.
    • If the screws are all removed, the motherboard should come off easily.
    FixBot'a Sor
    Yorum Ekle
  11. Samsung Galaxy Note Antenna Replacement: adım 11, 2 resimden 1. Samsung Galaxy Note Antenna Replacement: adım 11, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the three 3mm screws on the black rectangular bracket located towards the bottom of the phone.
    FixBot'a Sor
    Yorum Ekle
  12. Samsung Galaxy Note Antenna Replacement: adım 12, 1 resimden 1.
    • Use the spudger's flat end to disconnect the other end of the antenna.
    FixBot'a Sor
    Yorum Ekle
Sonuç
13 farklı kişi bu kılavuzu tamamladı.
David Ritter
758 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-45, Amido Spring 2013 Cal Poly, Team 3-45, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S3G45
4 Üyeler
28 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 16
Her zaman: 4,906
