Giriş
Before replacing the antenna, make sure your current antenna is the reason for you phone's problems. Check out the device's troubleshooting page to make sure your antenna is faulty. You may want to replace the antenna if your phone can't make calls or does not receive reception.
Neye ihtiyacın var
Make sure the screen is face-down and the camera is opposite you.
Insert the flat end of a spudger into the phone's top right rectangular slot.
Use the spudger as a lever to pry open the back of the phone.
Remove the nine 3mm screws on the perimeter of the phone with a Phillips #00 screwdriver.
Remove the two 3mm screws surrounded by a gold border with a Phillips #00 screwdriver.
13 farklı kişi bu kılavuzu tamamladı.
