Giriş
Before removing the headphone jack and earpiece, check the device's troubleshooting page. Make sure your headphones are not causing your sound problems before replacing the phone's internally connected headphone jack.
Neye ihtiyacın var
Make sure the screen is face-down and the camera is opposite you.
Insert the flat end of a spudger into the phone's top right rectangular slot.
Use the spudger as a lever to pry open the back of the phone.
Remove the nine 3mm screws on the perimeter of the phone with a Phillips #00 screwdriver.
