Ana içeriğe geç
Samsung Galaxy Note II Midframe Replacement
Sam Goldheart
Sam Goldheart ve 7 diğer katkıda bulunanlar
En son April 11, 2017 tarihinde güncellendi
10 dakika
Kolay
Use this guide to replace a Galaxy Note II midframe.
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
  1. Samsung Galaxy Note II Midframe Replacement, Stylus: adım 1, 2 resimden 1. Samsung Galaxy Note II Midframe Replacement, Stylus: adım 1, 2 resimden 2.
    • Grasp the end of the stylus and remove it from its slot in the midframe.
  2. Samsung Galaxy Note II Midframe Replacement, Rear Case: adım 2, 2 resimden 1. Samsung Galaxy Note II Midframe Replacement, Rear Case: adım 2, 2 resimden 2.
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  3. Samsung Galaxy Note II Midframe Replacement: adım 3, 3 resimden 1. Samsung Galaxy Note II Midframe Replacement: adım 3, 3 resimden 2. Samsung Galaxy Note II Midframe Replacement: adım 3, 3 resimden 3.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  4. Samsung Galaxy Note II Midframe Replacement, MicroSD Card: adım 4, 3 resimden 1. Samsung Galaxy Note II Midframe Replacement, MicroSD Card: adım 4, 3 resimden 2. Samsung Galaxy Note II Midframe Replacement, MicroSD Card: adım 4, 3 resimden 3.
    • If you have an SD card inserted, use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  5. Samsung Galaxy Note II Midframe Replacement, Battery: adım 5, 2 resimden 1. Samsung Galaxy Note II Midframe Replacement, Battery: adım 5, 2 resimden 2.
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
  6. Samsung Galaxy Note II Midframe Replacement: adım 6, 1 resimden 1.
    • Remove the battery from the midframe.
  7. Samsung Galaxy Note II Midframe Replacement, Midframe: adım 7, 1 resimden 1.
    • Remove the eleven 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
    In my phone some of the screws are litterally not ot turn - I screwed up one of the heads - be careful!
    erich zalcmann - Yanıt
    I have 2 note 2 phones model #: SGH-I317M. I have a broken screen that does not display in my note 2 but my brother's note 2 is working perfectly. Can I either transfer the motherboard in MY note 2 to my brothers note 2 or swap the broken screen with the new screen in my brother's note 2 ? Thanks. Reach me at anmac1789@gmail.com
    An Mac - Yanıt
  8. Samsung Galaxy Note II Midframe Replacement: adım 8, 3 resimden 1. Samsung Galaxy Note II Midframe Replacement: adım 8, 3 resimden 2. Samsung Galaxy Note II Midframe Replacement: adım 8, 3 resimden 3.
    • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
    • Slide the plastic opening tool down the seam.
    I didn't have an opening tool, so I used a stiff guitar pick. Worked like a charm.
    evanjpederson - Yanıt
    for best result without any scratches or breaking frame, open the frame on table (solid), don't open on hand.
    Chovav Sutachy - Yanıt
  9. Samsung Galaxy Note II Midframe Replacement: adım 9, 3 resimden 1. Samsung Galaxy Note II Midframe Replacement: adım 9, 3 resimden 2. Samsung Galaxy Note II Midframe Replacement: adım 9, 3 resimden 3.
    • Continue to run the plastic opening tool down the seam.
  10. Samsung Galaxy Note II Midframe Replacement: adım 10, 2 resimden 1. Samsung Galaxy Note II Midframe Replacement: adım 10, 2 resimden 2.
    • Carefully pry around the corner with a plastic opening tool.
    The screen cracked using that plastic tool.
    hell0allis0n - Yanıt
  11. Samsung Galaxy Note II Midframe Replacement: adım 11, 2 resimden 1. Samsung Galaxy Note II Midframe Replacement: adım 11, 2 resimden 2.
    • Pry along the top of the phone with a plastic opening tool.
  12. Samsung Galaxy Note II Midframe Replacement: adım 12, 2 resimden 1. Samsung Galaxy Note II Midframe Replacement: adım 12, 2 resimden 2.
    • Push the plastic opening tool down to free the corner of the midframe from the display assembly.
  13. Samsung Galaxy Note II Midframe Replacement: adım 13, 2 resimden 1. Samsung Galaxy Note II Midframe Replacement: adım 13, 2 resimden 2.
    • Free the clips along the power button side of the phone.
    • Lastly, free the two clips along the top and bottom edge of battery compartment.
    Start with the top clip. You can see it located next to the three battery connectors. Insert the spludge from the side gently to push, the clip should go off.
    Once this clip is off, the bottom battery clip can be unclipped simply by gently moving the two pieces apart.
    anonymous 4780 - Yanıt
    Gan kalok bluetooth hp saya sama wifi nya nggak bisa nelusurin jaringan apa nya yg rusak apa gara gara udah di root
    aryadana55 -
    If you're primarily following the pictures, as I was, you might be frustrated that your display assembly isn't popping off. Unfortunately, a vital step was listed in the instructions but not photographed:
    "Lastly, there are two clips along the top and bottom edge of battery compartment that also hold the display assembly in place."
    alimac70117 - Yanıt
  14. Samsung Galaxy Note II Midframe Replacement: adım 14, 2 resimden 1. Samsung Galaxy Note II Midframe Replacement: adım 14, 2 resimden 2.
    • Lift the display assembly out of the midframe.
    unblock the edge at the middle-up of the battery compart!
    Giorgio - Yanıt
Sonuç
52 farklı kişi bu kılavuzu tamamladı.
Sam Goldheart
472.110 İtibar
538 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.793 adet Kılavuz yazıldı
5Kılavuz Yorumları
There are two hidden clips near battery housing. One inside in upper part of battery housing and the second below battery near antenna.
milankerslager - Yanıt
How do I fix the glass
Nena Summer Perez - Yanıt
Very good job you are doing. It is very helpful to us. Thanks for sharing your knowledge to the people my wishes are with you god bless you.
HARDIK PANCHOLI - Yanıt
very very very useful brother
Arunkrishna T H - Yanıt
Brilliant Thanks.
michaeleggar6 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 30,489
