Ana içeriğe geç
Samsung Galaxy Note Micro USB Port Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. Samsung Galaxy Note Micro USB Port Replacement, Battery: adım 1, 3 resimden 1. Samsung Galaxy Note Micro USB Port Replacement, Battery: adım 1, 3 resimden 2. Samsung Galaxy Note Micro USB Port Replacement, Battery: adım 1, 3 resimden 3.
    • Make sure the screen is face-down and the camera is opposite you.
    • Insert the flat end of a spudger into the phone's top right rectangular slot.
    • Use the spudger as a lever to pry open the back of the phone.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Galaxy Note Micro USB Port Replacement: adım 2, 1 resimden 1.
    • With the spudger still inserted, carefully slide the spudger down the side of the phone.
    • Gently peel off the back cover with your hand.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Galaxy Note Micro USB Port Replacement: adım 3, 1 resimden 1.
    • Place the spudger in the battery's bottom right slot.
    • Gently pry to remove the battery.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Galaxy Note Micro USB Port Replacement, Midframe: adım 4, 1 resimden 1.
    • Remove the nine 3mm screws on the perimeter of the phone with a Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung Galaxy Note Micro USB Port Replacement: adım 5, 1 resimden 1.
    • Remove the stylus from the bottom of the phone.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung Galaxy Note Micro USB Port Replacement: adım 6, 3 resimden 1. Samsung Galaxy Note Micro USB Port Replacement: adım 6, 3 resimden 2. Samsung Galaxy Note Micro USB Port Replacement: adım 6, 3 resimden 3.
    • Pry all the way around the sides with a plastic pry tool and gently pop off the midframe.
    • If the cover does not come off easily, continue to pry along the phone's perimeter.
    • This step can take some patience. Prying too hard or forcing the screen off can crack or scratch the screen and break the thin plastic around the stylus case.
    • Separate the midframe from the phone. The midframe should now pull off easily.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung Galaxy Note Micro USB Port Replacement, Micro USB Port: adım 7, 1 resimden 1.
    • Turn the phone so the screen is on the table and the USB port is facing you.
    • Disconnect the orange ribbon near the bottom of the device using a spudger.
    FixBot'a Sor
    Yorum Ekle
  8. Samsung Galaxy Note Micro USB Port Replacement: adım 8, 1 resimden 1.
    • Remove the three 3mm screws on the bottom of the device with a Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  9. Samsung Galaxy Note Micro USB Port Replacement: adım 9, 1 resimden 1.
    • Remove the black rectangular bracket imprinted with a "7" where you just removed the screws. The piece should pop off easily.
    • Disconnect the antenna (white wire) with a spudger by prying the metal part gently off.
    FixBot'a Sor
    Yorum Ekle
  10. Samsung Galaxy Note Micro USB Port Replacement: adım 10, 2 resimden 1. Samsung Galaxy Note Micro USB Port Replacement: adım 10, 2 resimden 2.
    • Slide spudger under the USB port and gently drag it left and right to remove the port from the phone.
    • Adhesive keeps the USB port from moving, so it might not pull up right away.
    FixBot'a Sor
    Yorum Ekle
Sonuç
20 farklı kişi bu kılavuzu tamamladı.
David Ritter
758 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-45, Amido Spring 2013 Cal Poly, Team 3-45, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S3G45
4 Üyeler
28 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 35
Her zaman: 7,004
