Ana içeriğe geç
Samsung Galaxy Note9 Front Sensor Array Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Note9 Front Sensor Array Replacement, Eject the SIM card tray: adım 1, 2 resimden 1. Samsung Galaxy Note9 Front Sensor Array Replacement, Eject the SIM card tray: adım 1, 2 resimden 2.
    • Insert a SIM card eject tool straight into the hole in the SIM card tray.
    • Press to eject the SIM card tray.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Galaxy Note9 Front Sensor Array Replacement, Remove the SIM card tray: adım 2, 1 resimden 1.
    • Remove the SIM card tray.
    • The SIM card will fall out of the tray easily.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Galaxy Note9 Front Sensor Array Replacement, Apply a heated iOpener: adım 3, 1 resimden 1.
    • Power off your phone before beginning disassembly.
    • Use a hairdryer, a heatgun, or prepare an iOpener and apply it to the right edge of the back of the phone for about a minute to soften the adhesive underneath.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Galaxy Note9 Front Sensor Array Replacement, Insert an opening pick: adım 4, 3 resimden 1. Samsung Galaxy Note9 Front Sensor Array Replacement, Insert an opening pick: adım 4, 3 resimden 2. Samsung Galaxy Note9 Front Sensor Array Replacement, Insert an opening pick: adım 4, 3 resimden 3.
    • Apply a suction handle to the back cover.
    • Lift with a suction handle to create a gap between the back cover and the frame of the phone.
    • Insert an opening pick into the gap.
    • If the glass is badly cracked, cover it in packing tape to create a surface for the suction cup to adhere to.
    • If the adhesive won't budge, apply more heat, not excessive force. Too much force could break the glass.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung Galaxy Note9 Front Sensor Array Replacement, Cut through the adhesive: adım 5, 1 resimden 1.
    • Note that there is more adhesive along the top edge and around the camera bezel than around the rest of the phone.
    • Cut carefully around the left edge near the fingerprint sensor or you risk damaging the ribbon cable inside.
    • If, at any point, the adhesive feels stubborn, apply more heat—not more force.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung Galaxy Note9 Front Sensor Array Replacement, Slide the opening pick: adım 6, 3 resimden 1. Samsung Galaxy Note9 Front Sensor Array Replacement, Slide the opening pick: adım 6, 3 resimden 2. Samsung Galaxy Note9 Front Sensor Array Replacement, Slide the opening pick: adım 6, 3 resimden 3.
    • Starting from the center, cut the adhesive up and down the right side with an opening pick.
    • Do not insert the pick more than halfway into the phone when cutting near the fingerprint sensor or cameras, or you risk damaging internal components.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung Galaxy Note9 Front Sensor Array Replacement: adım 7, 3 resimden 1. Samsung Galaxy Note9 Front Sensor Array Replacement: adım 7, 3 resimden 2. Samsung Galaxy Note9 Front Sensor Array Replacement: adım 7, 3 resimden 3.
    • Be careful near the corner, as the glass is very weak. Apply more heat at any time if the adhesive becomes stuck.
    • Leave an opening pick in the upper-right corner.
    • Use another opening pick to cut the adhesive around the bottom-right corner.
    • Leave that opening pick in the phone.
    FixBot'a Sor
    Yorum Ekle
  8. Samsung Galaxy Note9 Front Sensor Array Replacement: adım 8, 1 resimden 1.
    • Use a heat gun or hair dryer or apply a heated iOpener to the left side of the rear panel for at three minutes to soften the adhesive underneath.
    FixBot'a Sor
    Yorum Ekle
  9. Samsung Galaxy Note9 Front Sensor Array Replacement: adım 9, 3 resimden 1. Samsung Galaxy Note9 Front Sensor Array Replacement: adım 9, 3 resimden 2. Samsung Galaxy Note9 Front Sensor Array Replacement: adım 9, 3 resimden 3.
    • Be careful near the corners, as the glass is weakest there.
    • Insert an opening pick into the lower-left corner of the rear panel.
    • Using another opening pick, cut the adhesive along the left edge of the rear panel.
    • Don't insert an opening pick in more than halfway on the left edge near the fingerprint sensor or you may damage the ribbon cable inside.
    • It is fine if opening picks fall out as the back cover becomes separated.
    FixBot'a Sor
    Yorum Ekle
  10. Samsung Galaxy Note9 Front Sensor Array Replacement: adım 10, 3 resimden 1. Samsung Galaxy Note9 Front Sensor Array Replacement: adım 10, 3 resimden 2. Samsung Galaxy Note9 Front Sensor Array Replacement: adım 10, 3 resimden 3.
    • Using the inserted opening pick, carefully cut the adhesive around the upper-left corner of the rear panel.
    • Finally, cut the last of the adhesive along the top of the phone.
    • Use an iOpener, hair dryer, or heat gun to apply more heat as needed where you are cutting the adhesive.
    FixBot'a Sor
    Yorum Ekle
  11. Samsung Galaxy Note9 Front Sensor Array Replacement: adım 11, 2 resimden 1. Samsung Galaxy Note9 Front Sensor Array Replacement: adım 11, 2 resimden 2.
    • Separate the right side of the rear cover first.
    • Tilt the cover up along the left edge to expose the fingerprint sensor ribbon cable.
    • Do not pull out the fingerprint sensor ribbon cable yet.
    • The fingerprint sensor cover might stay attached to the midframe.
    FixBot'a Sor
    Yorum Ekle
  12. Samsung Galaxy Note9 Front Sensor Array Replacement, Disconnect the fingerprint sensor: adım 12, 2 resimden 1. Samsung Galaxy Note9 Front Sensor Array Replacement, Disconnect the fingerprint sensor: adım 12, 2 resimden 2.
    • Use the tip of a spudger to pry the fingerprint sensor ribbon cable up and out of its socket.
    FixBot'a Sor
    Yorum Ekle
  13. Samsung Galaxy Note9 Front Sensor Array Replacement: adım 13, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Remove the back cover.
    • To re-install the back cover:
    • Use tweezers to peel away any remaining adhesive from the phone's chassis. Then clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth to prep the surface for the new adhesive. You don't have to clear out adhesive down to the plastic but larger pieces should be removed.
    • Turn on your phone and test your repair before installing new adhesive and resealing the phone.
    • Carefully apply the new adhesive to the back cover, then line up one edge of the glass against the phone chassis and firmly press the glass into the phone.
    FixBot'a Sor
    Yorum Ekle
  14. Dikkatli ol: adımlar 14-17 yapım altında olarak işaretlenen bir kılavuzdan alınmıştır.
    Samsung Galaxy Note9 Front Sensor Array Replacement, Remove the upper midframe: adım 14, 2 resimden 1. Samsung Galaxy Note9 Front Sensor Array Replacement, Remove the upper midframe: adım 14, 2 resimden 2.
    • Use a Phillips screwdriver to remove the nine 4 mm screws securing the upper midframe.
    FixBot'a Sor
    Yorum Ekle
  15. Samsung Galaxy Note9 Front Sensor Array Replacement: adım 15, 2 resimden 1. Samsung Galaxy Note9 Front Sensor Array Replacement: adım 15, 2 resimden 2.
    • Insert the tip of a spudger into the upper-left corner of the upper midframe.
    • Pry the upper midframe out of the phone.
    • The upper midframe snaps into and out of place.
    FixBot'a Sor
    Yorum Ekle
  16. Samsung Galaxy Note9 Front Sensor Array Replacement: adım 16, 3 resimden 1. Samsung Galaxy Note9 Front Sensor Array Replacement: adım 16, 3 resimden 2. Samsung Galaxy Note9 Front Sensor Array Replacement: adım 16, 3 resimden 3.
    • Peel the wireless charging coil off the battery starting with the left side.
    • The adhesive is weak but you can use an opening pick to cut it if necessary.
    • During reassembly start by snapping the midframe into place first before adhering the wireless charging coil.
    FixBot'a Sor
    Yorum Ekle
  17. Samsung Galaxy Note9 Front Sensor Array Replacement, Disconnect the battery: adım 17, 2 resimden 1. Samsung Galaxy Note9 Front Sensor Array Replacement, Disconnect the battery: adım 17, 2 resimden 2.
    • Use the tip of a spudger to disconnect the orange ribbon cable connecting the battery to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  18. Samsung Galaxy Note9 Front Sensor Array Replacement, Remove the midframe: adım 18, 2 resimden 1. Samsung Galaxy Note9 Front Sensor Array Replacement, Remove the midframe: adım 18, 2 resimden 2.
    • Remove the nine 4 mm Phillips screws from the plastic cover next to the battery.
    FixBot'a Sor
    Yorum Ekle
  19. Samsung Galaxy Note9 Front Sensor Array Replacement: adım 19, 1 resimden 1.
    • Remove the plastic cover next to the battery.
    FixBot'a Sor
    Yorum Ekle
  20. Samsung Galaxy Note9 Front Sensor Array Replacement: adım 20, 3 resimden 1. Samsung Galaxy Note9 Front Sensor Array Replacement: adım 20, 3 resimden 2. Samsung Galaxy Note9 Front Sensor Array Replacement: adım 20, 3 resimden 3.
    • Insert the tip of a spudger into the top of the lower midframe.
    • Pry the lower midframe out from the phone.
    • The lower midframe snaps into and out of place.
    • Remove the lower midframe.
    FixBot'a Sor
    Yorum Ekle
  21. Samsung Galaxy Note9 Front Sensor Array Replacement, Remove the front camera: adım 21, 3 resimden 1. Samsung Galaxy Note9 Front Sensor Array Replacement, Remove the front camera: adım 21, 3 resimden 2. Samsung Galaxy Note9 Front Sensor Array Replacement, Remove the front camera: adım 21, 3 resimden 3.
    • Use the tip of a spudger to pry the front camera connector straight up and out of its socket.
    • Use tweezers to remove the front camera.
    FixBot'a Sor
    Yorum Ekle
  22. Samsung Galaxy Note9 Front Sensor Array Replacement, Remove the iris scanner: adım 22, 3 resimden 1. Samsung Galaxy Note9 Front Sensor Array Replacement, Remove the iris scanner: adım 22, 3 resimden 2. Samsung Galaxy Note9 Front Sensor Array Replacement, Remove the iris scanner: adım 22, 3 resimden 3.
    • Use the tip of a spudger to disconnect the iris scanner from the motherboard.
    • Use tweezers to remove the iris scanner.
    FixBot'a Sor
    Yorum Ekle
  23. Samsung Galaxy Note9 Front Sensor Array Replacement, Disconnect the front sensor array: adım 23, 2 resimden 1. Samsung Galaxy Note9 Front Sensor Array Replacement, Disconnect the front sensor array: adım 23, 2 resimden 2.
    • Use the flat end of a spudger to pry the front sensor connector out of its socket.
    FixBot'a Sor
    Yorum Ekle
  24. Samsung Galaxy Note9 Front Sensor Array Replacement, Disconnect the display assembly: adım 24, 2 resimden 1. Samsung Galaxy Note9 Front Sensor Array Replacement, Disconnect the display assembly: adım 24, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the display cable from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  25. Samsung Galaxy Note9 Front Sensor Array Replacement: adım 25, 2 resimden 1. Samsung Galaxy Note9 Front Sensor Array Replacement: adım 25, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the touchscreen cable from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  26. Samsung Galaxy Note9 Front Sensor Array Replacement, Disconnect the charging assembly: adım 26, 2 resimden 1. Samsung Galaxy Note9 Front Sensor Array Replacement, Disconnect the charging assembly: adım 26, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the charging assembly from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  27. Samsung Galaxy Note9 Front Sensor Array Replacement: adım 27, 2 resimden 1. Samsung Galaxy Note9 Front Sensor Array Replacement: adım 27, 2 resimden 2.
    • Remove the three 4 mm Phillips screws securing the motherboard.
    • There are triangles next to the holes indicating the motherboard screw locations.
    FixBot'a Sor
    Yorum Ekle
  28. Samsung Galaxy Note9 Front Sensor Array Replacement: adım 28, 3 resimden 1. Samsung Galaxy Note9 Front Sensor Array Replacement: adım 28, 3 resimden 2. Samsung Galaxy Note9 Front Sensor Array Replacement: adım 28, 3 resimden 3.
    • Use a spudger to gently lift the motherbord from the upper-left corner.
    • Carefully remove the motherboard.
    • Move the ribbon cables out of the way as necessary. Do not pull the motherboard out if it becomes snagged on any cables.
    FixBot'a Sor
    Yorum Ekle
  29. Samsung Galaxy Note9 Front Sensor Array Replacement, Remove the front sensor array: adım 29, 2 resimden 1. Samsung Galaxy Note9 Front Sensor Array Replacement, Remove the front sensor array: adım 29, 2 resimden 2.
    • Use a pair of tweezers to peel back the adhesive-backed copper foil.
    • Stop peeling once you reach the sensor array.
    • Be careful not to tear the foil.
    FixBot'a Sor
    Yorum Ekle
  30. Samsung Galaxy Note9 Front Sensor Array Replacement: adım 30, 2 resimden 1. Samsung Galaxy Note9 Front Sensor Array Replacement: adım 30, 2 resimden 2.
    • Use the tip of a spudger to lift the left side of the front sensor array and separate the adhesive the rest of the way.
    • The front sensor array is still connected to a ribbon cable that is adhered to the phone. Do not try to remove the front sensor array yet or you will damage it.
    FixBot'a Sor
    Yorum Ekle
  31. Samsung Galaxy Note9 Front Sensor Array Replacement: adım 31, 2 resimden 1. Samsung Galaxy Note9 Front Sensor Array Replacement: adım 31, 2 resimden 2.
    • Carefully slide an opening pick under the front sensor array ribbon cable to cut the adhesive underneath.
    FixBot'a Sor
    Yorum Ekle
  32. Samsung Galaxy Note9 Front Sensor Array Replacement: adım 32, 2 resimden 1. Samsung Galaxy Note9 Front Sensor Array Replacement: adım 32, 2 resimden 2.
    • Use a pair of tweezers to remove the front sensor array.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Sam Omiotek
98.734 İtibar
290 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 52
Her zaman: 1,642
