Ana içeriğe geç
Samsung Galaxy Prevail Touch Screen Replacement
Ricardo Zuloaga
Ricardo Zuloaga ve 4 diğer katkıda bulunanlar
En son December 25, 2016 tarihinde güncellendi
15 - 30 dakika
Orta
Dilim ve Zar
By following this guide you should be able to fix issues with an unresponsive or cracked screen.
Neye ihtiyacın var
Aletler
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  1. Samsung Galaxy Prevail Touch Screen Replacement, Touch Screen: adım 1, 1 resimden 1.
    • Using your hands, carefully remove the back panel by popping the open slit, near the headphone jack, outwards.
  2. Samsung Galaxy Prevail Touch Screen Replacement: adım 2, 1 resimden 1.
    • Using your fingernail or nylon spudger, remove the battery by lifting upward in the recess of the bottom right corner.
  3. Samsung Galaxy Prevail Touch Screen Replacement: adım 3, 1 resimden 1.
    • Remove the (6) 4mm screws using a Phillips #00 screwdriver.
  4. Samsung Galaxy Prevail Touch Screen Replacement: adım 4, 1 resimden 1.
    • Using the black spudger, carefully unhinge and pry the secondary rear panel , which houses the camera lens and speaker.
    • The metal trim of the headphone jack may come loose during this process.
  5. Samsung Galaxy Prevail Touch Screen Replacement: adım 5, 1 resimden 1.
    • Using the spudger, gently pry upward on the motherboard by the right side.
    • Motherboard is connected to shield plate with ribbon cable.
  6. Samsung Galaxy Prevail Touch Screen Replacement: adım 6, 1 resimden 1.
    • Using a spudger, carefully unhinge the gray shield plate by lifting upwards on the right side.
    • The shield plate will not be fully removed, it is attached to the front panel with a ribbon cable.
  7. Samsung Galaxy Prevail Touch Screen Replacement: adım 7, 1 resimden 1.
    • Using the spudger lift up the LCD screen and replace with the new screen.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ricardo Zuloaga
537 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-6, Blackwell Fall 2016 USF Tampa, Team 17-6, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S17G6
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 20
Her zaman: 791
