Ana içeriğe geç
Samsung Galaxy Prevail Volume, Camera, & Power Buttons Replacement
Ricardo Zuloaga
Ricardo Zuloaga ve 4 diğer katkıda bulunanlar
En son December 25, 2016 tarihinde güncellendi
15 - 30 dakika
Orta
Eksik Adımlar
Dilim ve Zar
If the buttons are jammed, loose or damaged if can be frustrating trying to use the phone. This guide will show you how to replace any of the buttons in about 10-15 minutes.
Neye ihtiyacın var
Aletler
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  1. Samsung Galaxy Prevail Volume, Camera, & Power Buttons Replacement, Volume, Camera, & Power Buttons: adım 1, 1 resimden 1.
    • Using your hands, carefully remove the back panel by popping the open slit, near the headphone jack, outwards.
  2. Samsung Galaxy Prevail Volume, Camera, & Power Buttons Replacement: adım 2, 1 resimden 1.
    • Using your fingernail or nylon spudger, remove the battery by lifting upward in the recess of the bottom right corner.
  3. Samsung Galaxy Prevail Volume, Camera, & Power Buttons Replacement: adım 3, 1 resimden 1.
    • Remove the (6) 4mm screws using a Phillips #00 screwdriver.
  4. Samsung Galaxy Prevail Volume, Camera, & Power Buttons Replacement: adım 4, 1 resimden 1.
    • Using the black spudger, carefully unhinge and pry the secondary rear panel using the recessed tabs on the left and right sides.
    • The secondary rear panel houses the camera lens and speaker assembly,
    • The metal trim of the headphone jack may come loose during this process.
  5. Samsung Galaxy Prevail Volume, Camera, & Power Buttons Replacement: adım 5, 1 resimden 1.
    • Using the spudger, gently pry upward on the motherboard by the right side.
    • Motherboard is connected to shield plate with ribbon cable.
  6. Samsung Galaxy Prevail Volume, Camera, & Power Buttons Replacement: adım 6, 1 resimden 1.
    • Remove the desired button by pushing inward with the spudger or disconnecting the rubber pin connections.
Sonuç
Ricardo Zuloaga
537 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-6, Blackwell Fall 2016 USF Tampa, Team 17-6, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S17G6
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 276
