Ana içeriğe geç
Samsung Galaxy S II T989 Battery Replacement
Neye ihtiyacın var
  1. Samsung Galaxy S II T989 Battery Replacement, Rear Cover: adım 1, 3 resimden 1. Samsung Galaxy S II T989 Battery Replacement, Rear Cover: adım 1, 3 resimden 2. Samsung Galaxy S II T989 Battery Replacement, Rear Cover: adım 1, 3 resimden 3.
    • To remove the rear cover, locate the tab indicated by the red outline.
    • Using your fingernail, gently pry the rear cover.
  2. Samsung Galaxy S II T989 Battery Replacement, Battery: adım 2, 3 resimden 1. Samsung Galaxy S II T989 Battery Replacement, Battery: adım 2, 3 resimden 2. Samsung Galaxy S II T989 Battery Replacement, Battery: adım 2, 3 resimden 3.
    • Turn off the phone before removing battery.
    • The battery can be removed from the phone by applying an upwards pressure to the bottom right edge of the battery, as indicated by the red rectangle.
    • After the battery starts to lift upwards, use your hand to hold and remove it.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Joshua King
1.378 İtibar
9 adet Kılavuz yazıldı
Ekip
Clemson, Team 1-5, Benson Spring 2014 Clemson, Team 1-5, Benson Spring 2014 üyesi
CLEM-BENSON-S14S1G5
4 Üyeler
1Rehber Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 28
Her zaman: 2,913
