Ana içeriğe geç
Samsung Galaxy S20 Plus SIM/MicroSD Card Tray Replacement
Neye ihtiyacın var
  1. Samsung Galaxy S20 Plus SIM/MicroSD Card Tray Replacement, Eject the SIM tray: adım 1, 2 resimden 1. Samsung Galaxy S20 Plus SIM/MicroSD Card Tray Replacement, Eject the SIM tray: adım 1, 2 resimden 2.
    • Insert a SIM card eject tool, bit, or a straightened paperclip into the hole on the SIM tray, located at the top edge of the phone next to the plastic antenna band.
    • If you inserted the tool into the other hole, don't worry—the microphone and the ingress gasket are mounted out of harm's way.
    • Press in firmly to eject the tray.
  2. Samsung Galaxy S20 Plus SIM/MicroSD Card Tray Replacement, Remove the SIM tray: adım 2, 2 resimden 1. Samsung Galaxy S20 Plus SIM/MicroSD Card Tray Replacement, Remove the SIM tray: adım 2, 2 resimden 2.
    • Remove the SIM card tray.
    • The SIM card will fall out of the tray easily.
    • When you reinsert the SIM card, ensure that it is in the proper orientation relative to the tray.
    • A thin rubber gasket around the SIM tray provides water and dust protection. If this gasket is damaged or missing, replace the gasket or the entire SIM tray to protect your phone's internal components.
Sonuç
After you've completed the repair, follow this guide to test your repair.
Tarun Thiruma
35.445 İtibar
134 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 30
Son 30 gün: 128
Her zaman: 3,001
