Ana içeriğe geç
Samsung Galaxy S4 Cracked Front Glass Replacement
Neye ihtiyacın var
  1. Samsung Galaxy S4 Cracked Front Glass Replacement, Cracked Front Glass: adım 1, 2 resimden 1. Samsung Galaxy S4 Cracked Front Glass Replacement, Cracked Front Glass: adım 1, 2 resimden 2.
    • Your broken S4, may or may not be as damaged as the one shown in the photo.
    • I probably shouldn't have taken some of these photos in portrait, so my apologies but I'm forced to crop it.
    I have a question and I am hoping that you might be able to answer. My galaxy s4 dropped and the glass screen cracked it worked great even though it didn't look pretty. So I had my glass screen replaced by a business in my town and now when I type on it the letters write double or triple what it's suppose to and some of the icons on the lower left hand corner have to be pressed hard to get the app. to open also when scrolling down on something it opens up the page where i put my finger to scroll. My question is what do you think happened when they replaced the glass screen to make my phone act like this?
    orangedestiny87 - Yanıt
    For the problem you have here, there can be only two possible reasons. Either the digitizer went wrong or dust and debris weren't removed when putting on the new glass. You have to make sure absolute nothing is on the digitizer before putting on the glass beacause it can interfere with the phone's motion an sensors which makes the phones act weirdly.
    Jax Wang - Yanıt
    My screen shattered so bad that the image is black. And a few other colors. Phone still works because it will still ring and get text but obviously i can't view them. Can the screen be fixed when it's this bad?
    bharp0305 - Yanıt
    My samsung s4 has been dropped and it has got alot of glass coming off bht i cant replace it for a while because i have to pay for dance and sports but my question is if i dont get it fixed then can my whole phone just stop working???
    Bethanie Cowan-grainger - Yanıt
  2. Samsung Galaxy S4 Cracked Front Glass Replacement: adım 2, 3 resimden 1. Samsung Galaxy S4 Cracked Front Glass Replacement: adım 2, 3 resimden 2. Samsung Galaxy S4 Cracked Front Glass Replacement: adım 2, 3 resimden 3.
    • Remove the back plate, you can simply do this with your fingernail or a spudger.
    This is hard to do I'm just going to the mall to fix it
    Cheyenne Durand - Yanıt
  3. Samsung Galaxy S4 Cracked Front Glass Replacement: adım 3, 2 resimden 1. Samsung Galaxy S4 Cracked Front Glass Replacement: adım 3, 2 resimden 2.
    • Simply remove the battery using your fingernail or spudger. No cables are attached so it is basic.
    • If you have a SIM card in the phone, push it inwards then release to eject it.
  4. Samsung Galaxy S4 Cracked Front Glass Replacement: adım 4, 2 resimden 1. Samsung Galaxy S4 Cracked Front Glass Replacement: adım 4, 2 resimden 2.
    • Heat up the glass for 3-5 minutes. I chose to do it for 4 minutes.
    • You only need to use your heatgun on the lowest setting. I wouldn't recommend using a hair drier as it doesn't get very hot.
    • You must be careful when using the heat gun on this device. If the device is heated up too much then it may melt the digitizer and cause discoloration. If you start to see any discoloration then shut off the gun immediately.
    • This procedure softens the adhesive that holds the glass to the screen assembly.
    But could we use a hairdryer?
    Daelin Jackson - Yanıt
    There's a guy with a channel "jerryrigeverything" who has plenty of these repairs on You Tube. If I remember correctly, he says to heat the glass to between 180 f and 205 f. You should use an infrared thermometer to be safe.
    mcr4u2 -
    Yea hairgun can be jused...the glue will be easy to take off about 80c and this is safe!
    Stay away from metal tools and juse plastic cards "deck cards" this will make the screen perfect without anny scratches!
    takk4maten - Yanıt
    To be safe I recommend removing the motherboard and camera etc to avoid possible damage when heating. Its easy to do, just 2 screws and a few clip on wires. Worth the extra 2min work.
    Kraiye - Yanıt
    You definitely don't need a fancy thermometer. Just heat it till the glass is to hot to hold but not hot enough to burn. BE PATIENT and keep testing it by trying to separate it. You'll need to reapply heat every minute or so while removing the glass.
    Kraiye - Yanıt
  5. Samsung Galaxy S4 Cracked Front Glass Replacement: adım 5, 2 resimden 1. Samsung Galaxy S4 Cracked Front Glass Replacement: adım 5, 2 resimden 2.
    • After you've used the heatgun, you want to start by separating the edges of the glass from the rest of the phone, starting from the top.
    • I used a metal spudger initially, if you're going to use a metal spudger as well you want to be careful to not damage anything.
    I did everything correctly but my led isnt showing up. Can I fix the flex cable in the upper left corner?
    Peter Pan - Yanıt
    there is no way to fix the flex.
    you have to change the whole screen.
    if you want get into my youtube channel i got many videos about fixing samsung galaxy
    youtube.com/gabakusa
    i hope it helps
    Gabriel Barrandeguy -
    Only use metal on the corners JUST TO GET IT STARTED! Then switch to something plastic. Make sure the spudger is only lifting the front glass and not the digitiser or lcd
    Kraiye - Yanıt
  6. Samsung Galaxy S4 Cracked Front Glass Replacement: adım 6, 2 resimden 1. Samsung Galaxy S4 Cracked Front Glass Replacement: adım 6, 2 resimden 2.
    • Work your way around the edges with plastic picks.
    • Take your time otherwise the glass will shatter (see second image).
    • If your screen is overly cracked (looks like spiderwebs) you will want to put several layers of packing tape over your screen to try to keep it in one piece and do everything in your power (go slowly and don't be shy with the heat) to prevent it from shattering more.
    • Caution: If your glass happens to shatter you might want to consider wearing safety glasses.
    • Plastic razor blades you find in a hardware store are great for intricate cleanup like this. Alternatively try guitar plectrums (picks) from a music shop. These won't scratch the digitizer.
    Make sure you get your spudger between the glass and the digitizer. It is very easy to get between the digitizer and LCD. AND WORK SLOWLY!!!! PATIENCE!!!!
    Tim Yorba - Yanıt
    In this progress it is mutch better to juse a plastic deck card "poker card" and gently drag it trough the screen! make sure the temperature is always right! Start always at the top to bottom!
    takk4maten - Yanıt
    It takes me 5 min to take off the glass with a card, 1 hour with the spunge tools!
    takk4maten - Yanıt
    dont be surprized if you crack your lcd! there is a balance between heat to soften the glue while not burning the lcd!
    prudhommejc - Yanıt
  7. Samsung Galaxy S4 Cracked Front Glass Replacement: adım 7, 1 resimden 1.
    • Re-heat the glass frequently. If you find that the glass isn't coming off easily you will want to apply more heat and then continue.
  8. Samsung Galaxy S4 Cracked Front Glass Replacement: adım 8, 1 resimden 1.
    • I never got any photos, but when taking the glass off be very careful near the two touch keys at the bottom of the phone as it can be easy to damage them. They are stuck to the glass and need to be taken off before lifting off the glass.
    • With the glass removed, you'll end up like your phone looking like this, with the adhesive residue leftover on the digitizer.
    how do you take the buttons off?
    sinead - Yanıt
    If you're talking about the touch keys at the bottom, slide a thin tool between the glass and the touch keys on the underside of the glass carefully as it's held by adhesive
    Patrick Lee -
    I've just replaced the screen on my s4. But when I turn the phone back on, there is sound but the screen remains black. I thought the digitiser had broken but when I press down on the screen things are still happening. I just can't see why I'm doing. Anybody have any idea.
    Luke green - Yanıt
    you very likely broke something in the LCD assembly... It's a $200 replacement but it's not as difficult a repair.
    Doug Bishop -
    follow this video i made it will help you
    how to change display galaxy s4 (LCD frame in few steps)
    https://www.youtube.com/watch?v=85pOvI6O...
    Works perfect - read all the pictures before you begin, be patient, it is an expensive repair at the shop, nibble away with loads of reheats. Sharp scalpel is also useful. Good Luck
    Frank - Yanıt
    My screen just broke, and I've ordered a replacement. I've been thinking about filling a hot-water bottle with boiling water and letting that sit on top of my phone for 5-10 minutes before starting. I can't think of a reason why this wouldn't be easier than using a hair-dryer/heat-gun. At least to get me started...
    crowops - Yanıt
    heat gun with temp control is the best
    here in this video i explain the theory of how it must be done.
    https://www.youtube.com/watch?v=qOAauYYN...
    samsung galaxy s4 changing broken glass with uv glue LOCA
    https://www.youtube.com/watch?v=wCeoVSVw...
    Gabriel barrandeguy -
    I wish that the step 8 was highlighted! The back and home buttons are so SENSITIVE! I ended up breaking the menu button! Dam it.... now I have no phone untill the button replacement!
    Cheney Bush - Yanıt
    Download the app "Button Savior". It adds a small pop-up window that has all your physical buttons, including the home button. Not only does this give you broken buttons back, but it also extends the life of your physical buttons due to less use.
    Cody Giles -
  9. Samsung Galaxy S4 Cracked Front Glass Replacement: adım 9, 2 resimden 1. Samsung Galaxy S4 Cracked Front Glass Replacement: adım 9, 2 resimden 2.
    • Clean up the digitizer with lint free wipes or a clean microfiber towel. I used some lens cleaner on a microfiber cloth to clean mine up.
    • I probably did a terrible job of removing the glass and the digitizer appears scratched. If yours does look like this as well it's no problem, when the screen is turned on it's not noticeable.
    • If you want to really get the screen almost perfectly clean or if the glue residue won't come off, use some acetone-free nail polish remover. It takes only a few seconds to get all the dirt off and it will evaporate: it will look nearly flawless when you are done.
    I would not recommend to use a razor on your actual LCD. I do however, recommend nail polish remover (WITHOUT ACETON!!!) and a cloth. With windex it took forever, with the nail polish remover the residue came of in a matter of seconds. The added advantage is that it evaporates after the dirt has been wiped off the screen, instead of the oil you propose which will make your screen greasy and will not make the UV glue bond very well with the LCD.
    Jarno De Bruyn - Yanıt
    Superbe tutoriel, merci ! Pour nettoyer l'écran, j'utilise de l'essence F : se trouve en magasins de bricolage. C'est très utilisé en modélisme. Un petit peu sur un coton-tige, on applique sur l'écran en balayant latéralement, puis on essuie avec un essuie-tout. Résultat impeccable, et en plus ça m'a permis d'enlever les petits résidus de colle sur le bord.
    Etienne Arbogast - Yanıt
    ACETONE is the best option!!!!!!
    takk4maten - Yanıt
    Acetone can damage certain materials like plastics. You'd have to be VERY careful of how and where to apply. Without acetone, you don't have to worry about anything, which makes the process go a lot faster.
  10. Samsung Galaxy S4 Cracked Front Glass Replacement: adım 10, 1 resimden 1.
    • Place the new adhesive around the edges of the phone. If the screen you purchased didn't come with any you can use 3M 2mm strips.
    • Peel off the blue bit on the top of the adhesive.
    I'm using 2MM tape, and when the glass goes on touch won't register. When it's off, it works fine. Ideas?
    IzzK - Yanıt
    How do we handle the space on the LCD it self? Are we replacing the adhesive we removed before?
    Will - Yanıt
    pd: UV glue will fill that space.
    can have any substitue for heating gun. can i apply some other method to heat up the glass to remove it from screen
    aftabkankroli - Yanıt
    Hair dryer will do the trick too
    I have the blue adhesive that is in the picture, but i'm not sure how to apply it properly. help?
    Autumn Scornaienchi - Yanıt
    did you watch the video i have post? i show step by step how to apply the glue.
    hi if i use the blue Optically Clear Adhesive how would i put it on. do i put it all on the screen then i pill and put on the glass
    abelmanuel94 - Yanıt
  11. Samsung Galaxy S4 Cracked Front Glass Replacement: adım 11, 2 resimden 1. Samsung Galaxy S4 Cracked Front Glass Replacement: adım 11, 2 resimden 2.
    • Prepare your new glass. If yours is covered both sides like mine then only remove the under side for now.
    • Do not touch the underside or get any other dust or marks on it, if you do clean it off first.
    new glass price pls pls
    kafi2000 - Yanıt
    you can buy it on ebay
    What is this price
    Usman Gujjar - Yanıt
  12. Samsung Galaxy S4 Cracked Front Glass Replacement: adım 12, 3 resimden 1. Samsung Galaxy S4 Cracked Front Glass Replacement: adım 12, 3 resimden 2. Samsung Galaxy S4 Cracked Front Glass Replacement: adım 12, 3 resimden 3.
    • Put the new glass on the phone.
    • *EDIT* LOCA glue should be used when assembling the screen. There are some good videos on youtube showing how to apply the glue.
    • Be very careful to prevent the glue from getting in the top (ear piece) speaker and on the front facing camera lens.
    • Peel off the top plastic cover on the glass.
    when replacing the screen, does the adhesive glue go between the actual screen and digitizer or just around it?
    jonathon lacy - Yanıt
    yes it goes in the middle the glue.
    here is it a test to post a video
    [video|https://www.youtube.com/watch?v=wCeoVSVw...|]
    Gabriel barradenguy -
    I have a question.. when I put the new front glass, I have some issues with bubble of air between the glass and the digitaizer.. how to fix that?
    Antonio Rosapallida - Yanıt
    If you're using LOCA glue, before it's cured you can "chase" the bubbles out to the edge of the screen. Use your finger to put gentle pressure behind the bubble and follow it out, then cure the glue with UV light.
    whsorensen -
    It's necessary to put LOCA glue or just with the adhesive tape is ok?
    Jose Pilero - Yanıt
    I would totaly recommend the loca it makes the touch nice and the screen will handle more damadge dure to the elastic glue!
    takk4maten -
    if i don't put the glue then what will happen or it just an option?
    Walid Ismail - Yanıt
  13. Samsung Galaxy S4 Cracked Front Glass Replacement: adım 13, 1 resimden 1.
    • Place the battery (and SIM card) back in.
  14. Samsung Galaxy S4 Cracked Front Glass Replacement: adım 14, 1 resimden 1.
    • Put the back plate back on and turn your phone on! :)
Sonuç
Enjoy your S4 without the cracked screen!
272 farklı kişi bu kılavuzu tamamladı.
Patrick Lee
6.968 İtibar
2 adet Kılavuz yazıldı
79Kılavuz Yorumları
Tried it, wrecked the LCD, had to buy a new front assembly :(
Tim - Yanıt
That's unfortunate, sometimes in some unlucky cases the LCD or digitiser tries to come up with the glass which probably means it needs to be heated up for longer with the heatgun.
Patrick Lee -
Same here. The glass was spiderwebbed and it was frustrating work. About 2 hrs in I must have gotten a little careless because a little extra force and boom...LCD broken.
If your glass has more than a few cracks in it I would say it's not worth the effort-replace the whole display or take it to a professional.
Logan Kennedy -
here i made a video how to do that, i hope it helps you
Can I put on the complete adhesive ? Or must I leave holes ?
florianholtgen - Yanıt
You'll need to leave holes otherwise you may cover the sensors or other components to the phone.
Patrick Lee -
I do the s3's this way all the time. I did break the first one I ever did. The s4 is very different from the s3. I just tried it and broke the LCD. The LCD was pulling up with the glass, didn't realize I had my pick UNDER the LCD as well. Never had that issue with the S3. Also the glue seems stronger than the glue on the S3, its melting point has to be different in my opinion.
cmantlo - Yanıt
here i made a video explaining everything in a white board how it has to be done for the next time
i hope it help you
Theory of how to fix gorilla glass at any samsung galaxy
Just finished up, and everything worked out just as planned. Had some trouble keeping the cracks from cracking even further, but the LCD is undamaged and there isn't any discoloration. The only issue I have is from the original adhesive. There are parts where it still shows through, even with the screen on, so make sure when going through this to COMPLETELY clean off any leftover residue from the original screen. Other than that, a very easy fix. Took about an hour.
Xerilyn - Yanıt
As one person has already commented, the front glass is much more difficult to replace on this phone than it is on the Galaxy S3. Didn't realize when I was doing it that I had lifted up the LCD with the pick, meaning i had to replace the full display assembly. I would be tempted to have another ago, just make sure you apply plenty of heat and are very careful.
Adam - Yanıt
Have repaired a few and part of the process is to replace the adhesive with a liquid one that is poured on the amoled panel and cured after the glass is carefully placed. Any UV light, like for nails, or sunlight will cure the LOCA (Liquid Optically Clear Adhesive). To avoid getting this adhesive on anything in the s4 you should remove everything from the inside: parts, boards, rubber gaskets, etc. also use double-sided tape for the edges around the display to help the liquid adhesive stay away from where the camera, proximity sensor and ear speaker will go. the entire process can take about 2hrs but can be as short as 45 min if you have quicker heating methods than a heat gun like a hot plate. The durability of the device is affected but the adhesives holding the lens in place and not replacing them will make the glass easier to break later on.
Stephen Napoleon - Yanıt
While this suggestion is more professional, it requires more time and resources that aren't completely necessary, or maybe not for your average repairer. Of all the S4 screens I've replaced I use the basic adhesive that comes with the glass from my supplier and that has enough strength to hold the glass in place when it is applied correctly. This was interesting though, thanks!
Patrick Lee -
I don't know if the S4 is the same in this aspect, but not using LOCA also can cause freezes if the screen is 'pressed' too hard on the S3. That said, the only time I've tried to do the LOCA on an S3, the adhesive got EVERYWHERE. Eventually the touchscreen stopped working and I had to buy a new front housing/LCD/digitizer. I assume I used too much glue, but I also felt the LOCA didn't spread properly, as the top corner of the phone received no LOCA and the bottom seemed to get the majority of it despite using the same technique as many guides I saw. I managed to push and spread the glue to the corner but pushing it in that fashion really helped glue up everything. The screen looked much better with the LOCA instead of just the adhesive along the side, though.
TL;DR: LOCA makes things look and work a lot better, but if done wrong it can really screw things up
Dave Davidson -
A friend told me that when my glass is broken then this may affect the device memory that after a month it will melt and the whole device will broke . Is this true?? I mean is that possible to happen?? What should I do ??
Muhammad - Yanıt
Your friend is lying to you and doesn't know anything he is saying either, you probably should believe everything people say.
Patrick Lee -
Mmm he said that the wires that is linked to "emmc" ,which have something to do with inner memory, may melt because of heat which these wires moved a bit because of damage .anyway he said that this may cuz sudden death ....any suggestions . And thx a lot
Muhammad - Yanıt
I just broke the screen on my S4 Active? Is the process the same as it is with the regular S4. I can't find a step by step guide to removing the glass.
Miranda - Yanıt
i hope it help you
You are supposed to put clear box tape over the glass before heating it. This will suck all of the glass into the tape and prevent damage. This step by step is alright but you want little to none scratches, dents or smears on the digitizer.
elideville - Yanıt
Great suggestion!
Patrick Lee -
I've just managed this no problem. If you are having problems cleaning the digitiser properly you can use a bit of surgical spirit on a lint free cloth to clear the remnants off better
Stephen Wilkinson - Yanıt
This is called isopropyl alcohol or isopropanol and costs 2-5$/Liter.
Lololo -
I had no real problems with this. It was more time consuming than difficult. Taking the glass off and cleaning the digitizer took about 45 minutes, but after that it was easy.
Andrew - Yanıt
So I replaced glass with minor issues, used LOCA and UV light. Phone turns on fine with all buttons working, but the touch screen doesn't register ANYTHING. There are no visible cracks or discoloration, I would describe it almost like screen is froze? Did I just make myself buy a new digitizer assembly?
Tom McDowall - Yanıt
take the back case off and make sure you connected all cables to the main board and the usb board in the lower left corner
tlagabid2 -
So i just did this turned my phone back on and the entire lcd is discolored showing up mostly green but fades in and out when i turn on/off the phone. any advice at this point? do i need to have the LCD completely replaced now?
Jack Gleason - Yanıt
Did this last night. Only tricky part was actually the application of the adhesive for the replacement glass. Didn't really match what I needed and the picture above was a bit unclear that you DO NOT want to apply adhesive over the LCD screen!
Anyway, here are my repair pics: https://plus.google.com/photos/110629972...
Dan
Daniel Hadad - Yanıt
So I started replacingy glass but I realized that I was taking of the entire LCD and so I stopped mid removal of the glass and pushed it back together and havent made another attempt do u think my phone is permanently damaged. Its been working fine but I feel like at any moment the screen is gonna fall out. Scratch on the glass wasn't even noticable only affected my selfie pics
justine - Yanıt
How long roughly will it take using a hair dryer?
mortbals16 - Yanıt
depend of the hair dryer , you got to get 100C or you will break the screen
here it is the theory i made about it
what the whole video before it is to late
I went to a professional, where i live in pakistan these professionals arent very professional:p they lie and everything so my screen just the glass was cracked and my digitizer was fine. a few months ago i had replaced my digitzer which cost me almost 200 dollars and it was original however when i went to change my cracked glass a few months later, the guy at the shop he changed the screen and it had scratches on it i asked him why so he said the digitzer was fake thats why the new glass got scratches on it while we were replacing it. FIrst of all im pretty sure i got an orignial digitzer but even if i didnt, does it have to do anything with the new glass having scratches on it?
Asad Raza - Yanıt
Hello- where can I buy replacement glass for the S4 Active? All I can find on amazon is glass for the S4. Are they the same?
Bridgette - Yanıt
did u try to find it on ebay or amazon?
i broke my galaxy s4 and the screen is fully black i turn it on and there is no light to it what pieces do i need to fix it? do i just need a front screen or is there another screen i need to buy?
molinacarmen13 - Yanıt
here i made a video that will help you with that
I dropped my s4 and my screen has completely gone! The phone still switches on and I can hear messages coming through and still receive calls. Do I just need a new screen and will it fix my problem completely?
David - Yanıt
If you can still hear messages coming in then it sounds like you need a new lcd. I have fixed a few S4's with the same symptoms. I did run across 1 S4 that was dropped hard enough that the LCD cable inside came disconnected. I re-attached the cable and everything was fine even the LCD was not cracked. Funny enough a couple days later I ran into the same thing on an Iphone 4, loose/disconnected cable.
Tim Yorba -
here i made a video about changing the LCD, if that is your case.
if you want to change the gorilla glass by itself here it is other
enjoy
i hope you can fix your
best regards
gabe
Hi, i just did it!
Everything looks very good and i checked the function before i used the uv-glue.
After i finished now, the display don't react properly.. For example i can't click ok when i have to type the sim pin.
I can click 1 4 5 6 without problems. when i click 7 8 9 it works sometimes and ok dont work...
Maybe you have an idea what happened? I am not sure what i did wrong.
When i try to turn the phone off, i can't click anything after the menu appears. I can't even click in areas, that worked before?
GodNoob - Yanıt
When applying heat to soften the adhesive, do i need to slowly move around the whole screen for 4 minutes, sorry if it's a daft question.
How do you know if the heat gun is causing discoloration when the phone is not on, what signs do i need to look for?
Also i'm assuming you need to heat on the middle of the glass probably mostly because that's the strongest adhesive patch to remove from.
James - Yanıt
samsung galaxy s4 changing broken glass with uv glue LOCA (HERE IT IS STEP BY STEP PROCESS)
Our Comments system is currently undergoing maintenance, and will be back shortly. -The iFixit Team
Dominique - Yanıt
My screen looks exactly like yours in the picture. When I dropped it I could still see the picture on the screen but it slowly disappeared and is now completely black. Will replacing the screen fix that as well? Thanks, Mike
Michael Gray - Yanıt
yes it will fix that.
check my youtube channel GABAKUSA i made many videos how to fix that.
This was great thank you for the help, but some how I got air bubbles under my glass lens. How do I get them out?
chance - Yanıt
burst them, they appear cuz did nt release the glass slowly enough.
what this video about the theory i made so you wont make more mistakes ;-)
it is like 1 hour long
I did it an now the phone wont turn on. What do i do
john jelinek - Yanıt
Be careful and work slowly. My wife did it, and it is now good as new!
ivanmcruz32 - Yanıt
I'm curious to know if there are people out there who have experience doing this repair WITHOUT using the LOCA glue and UV light. Are your results good as far as phone function and operability? Or do you think using just the precut adhesive alone is NOT enough?
Anthony James - Yanıt
go to my youtube channel gabakUSA i have fixed many with and without uv glue.
without glue dirt maybe get in to the LCD and sometime it maybe lock the screen itself.
so it is better using glue for the long run
It will cost me the same price to bring it to the shop and let them repaire it instead of bying a new scren and take al the risk of breakink it.....
Why should I bye it?
lucly - Yanıt
I was wondering if this is going to work for my phone. I cracked the top right side of my phone. Now there is nothing. I turn it on and it's just black. Is that cause the screens cracked? Shouldn't it still light up or something? So I'm just wondering if replacing the screen will work or should I just get a whole new front with the LCD and digitizer?
Steve - Yanıt
Question 1: If you take out the battery, then how can one tell if there's discoloration when applying too much heat?
Question 2: what would the perfect amount of pressure to apply in removing the screen feel like, or more importantly what would be too much pressure?
Try giving an easily relatable eample, such as 'the pressure given on a pencil and an electric pencil sharpener'
Genny Smith - Yanıt
What else can you use besides a heat gun I have the ifixt heating thingy will that work
georgeperez26 - Yanıt
I used a heat gun and a playing card from a deck of cards to remove the glass. DO NOT use anything metal and DO NOT lift the card when sliding it under the glass. If you keep it flush you should have no problems removing the glass and won't break the LCD.
I tried using loca glue and it is a pain and messy. As long as you use good 3M adhesive tape and a good quality glass lens, no need for LOCA.
Mike Lamothe - Yanıt
Tons of people are saying you should probably just give up if the glass is spiderwebbed, because you'll break the display/digitizer.
I disagree entirely. This method of just applying upward pressure is the issue, not the glass. Pick up a spool of Molybdenum wire and use it to "cut" the LOCA under the glass. Using the wire puts considerably less stress on the LCD.
jakejarrett - Yanıt
Thanks for the good tip.
Nicola Centrone -
Did it. But I overheated the display in one spot. Now it has a pink-magenta color there. Is there something I can do now? Touch working perfectly everywhere on the screen. Thanks.
Z4H3R - Yanıt
hey there exellent instructions i replace the glass in about an hour the only advice i could give is use a poker card/playing card maybe 5 as they get glue all over them instead of spatula or razor blade and use a heat gun or heat plate cos a hair dryer does not give enough heat g o max 80 degrees only use razor blade to get the top right of the screen up not the left side as there is a ribbon and remember to stop once you get to the home button as is 2 more ribbons for the back key an multi task key lift the screen to a 45 degree and carfully remove the back/multi task buttonswith razor blade bang your done best a luck☺
rhys t - Yanıt
Who can tell me when can I bye a new glass screen for Galaxy S4?
Anisa Murati - Yanıt
my s4 is cracked all over and i need to know if it is easy to remove without the tape. its all tiny cracks.
jake satterwhite - Yanıt
i took off the glass without damaging the LCD,but the touch doesnt work anymore.As i know it has to react without the glass...or not?Can somebody help me with this ?
zoli prodan - Yanıt
Folks, I have done this, but now the screen doesn't turn on, it responses to the touch with sound, but no image.
Sam Kultz - Yanıt
Hi good afternoon , my Samsung Galaxy S4 Display is Brock, and i want to change the display, may i know how much the price,,,
Pasang Sherpa - Yanıt
Question :what kind of heat gun needs to be used to remove the screen an where can they be bought. Thanks, Lorraine
Lorraine Young - Yanıt
Will this fix response because my Samsung is both cracked and not responding.so sad I don't deserve this.
Matthew Kuan - Yanıt
Please comment
If my phone is cracked to the point where the screen is always black what does that mean? Is my LCD or digitizer broken? Because it turns on and the sound works and whatnot and so does the rest of the functionality, i just can't see anything. Do i need to replace the front assembly?
Anthony Washington - Yanıt
Nice one! Made it look easy least the steps eazy to follow. Thanks great resultn my s4 needs doin so very helpful article thanku
Joanna Eldridge - Yanıt
It worked i followed every step thank you so much.
Kaleb - Yanıt
Thanks - I used this procedure to replace the front glass on my S4, two S2's and a sony Z3 Compact back glass. I broke the LCD on one of the S2's but the rest worked.
Heated glass w/ my hairdryer for 2 minutes, lifted a corner up w/ my fingernail, slid plastic pick under glass. Heated again, slid pick to other corner. Added another pick to keep glue from reattaching (one in each corner). Heated and worked the picks until the whole thing was raised. There were a couple bits sticking to electronics, be careful to cut or separate this glue so it doesnt take the buttons/electronics up, then lift off the screen. Used plastic, thin gauge guitar picks and not anything metal, to avoid damage to the LCD. If you need to start a corner with a tiny flathead screwdriver, do it only to lift the corner enough to slide a pick in then stick to plastic. Clean edges gently with spirits. Do not put any pressure on exposed LCD. Put on new glass, heat for 3 minutes, put clothes pegs all around the rim and set for 2 hours.
the bean - Yanıt
Why we should use loca glue....? Is it important....? What the purpose of local glue.....?
mapeecreation - Yanıt
yes it is important or the sensitivity wont be the same, also dust my will get inside.
here i made a video where i explain in more detail https://www.youtube.com/watch?v=qOAauYYN...
Do yourself a favour, spend the extra few $ and get some LOCA glue. Watch a bunch of tutorials on how to use it.
I didn't :( and now my screen is hyper sensitive and swype doesn't work properly. I've ordered some LOCA and will be redoing it properly.
Kraiye - Yanıt
Thank you so much for this tutorial. Just finished and all is working. No lunch for kids but phone is fine ;-))) Better start cooking now. My phone was terribly shattered, like crazy shattered. I used nail polish remover to clean at the end. I was so worried but quite careful. You saved me lots of money as I was about to buy new phone cause I go on long holidays with kids in few days time and how can you live without the phone these days ;-))) but decided to give it a go. THANKS AGAIN ;-))))))))) Hope I don't have to do it again ;-))))) And it costed me under 8 Euro for new screen and that's all ;-))) and I used hair dryer
takajola - Yanıt
Hi guys.
I cannot comprehend one thing i am reading
"Dropped and cracked the screen on your Galaxy S4? No problem, follow this guide instead of needing to replace the entire display assembly.
To prevent shards of glass from scratching your LCD, or getting all over your workspace, place a wide strip of tape over the entire screen."
i think it will be good to be more specific what kind of type - basic which the kids are playing with, thermoresistance tape or ?
whatever460 - Yanıt
chill out man he is just trying to help some people out
Raymond Torres -
that was so cool and easy
kabaalu shabil - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 11
Son 30 gün: 82
Her zaman: 1,408,467
