Ana içeriğe geç
Samsung Galaxy S6 Active Battery Replacement
Neye ihtiyacın var
  1. Samsung Galaxy S6 Active Battery Replacement, SIM Card: adım 1, 2 resimden 1. Samsung Galaxy S6 Active Battery Replacement, SIM Card: adım 1, 2 resimden 2.
    • Insert your fingernail or a plastic opening tool into the pivot on the side of the SIM tray.
    • Pry open the tray to get it out of the socket.
  2. Samsung Galaxy S6 Active Battery Replacement: adım 2, 1 resimden 1.
    • Remove the SIM tray with SIM card from the phone.
  3. Samsung Galaxy S6 Active Battery Replacement, Display Assembly: adım 3, 3 resimden 1. Samsung Galaxy S6 Active Battery Replacement, Display Assembly: adım 3, 3 resimden 2. Samsung Galaxy S6 Active Battery Replacement, Display Assembly: adım 3, 3 resimden 3.
    • Heat the front face (sides, top, bottom) of the phone with the iOpener, a hair dryer, or a heat gun for 60 seconds to loosen the adhesive around the edge of the glass.
    • If using an iOpener, heat it in a microwave for thirty seconds.
  4. Samsung Galaxy S6 Active Battery Replacement: adım 4, 1 resimden 1.
    • Attach a suction cup to the lower half of the screen.
  5. Samsung Galaxy S6 Active Battery Replacement: adım 5, 2 resimden 1. Samsung Galaxy S6 Active Battery Replacement: adım 5, 2 resimden 2.
    • Using the suction cup, pull gently the lower half of the panel.
    • If you pull too hard you may break the display. If you still feel resistance repeat Step 3, leaving the iOpener on longer.
  6. Samsung Galaxy S6 Active Battery Replacement: adım 6, 3 resimden 1. Samsung Galaxy S6 Active Battery Replacement: adım 6, 3 resimden 2. Samsung Galaxy S6 Active Battery Replacement: adım 6, 3 resimden 3.
    • Once you’ve opened a large enough gap, insert a plastic tool at the bottom, between the glass and the rest of frame of the phone.
    • Slide the plastic opening tool around the screen, prying the display gently away from the body
  7. Samsung Galaxy S6 Active Battery Replacement: adım 7, 1 resimden 1.
    • Pull the lower half of the screen screen with the suction cup while holding down the frame of the phone to separate both components.
    • Only lift the lower part of the screen. It is connected with a clip to the top of the motherboard and can rip off if you pull too hard.
  8. Samsung Galaxy S6 Active Battery Replacement: adım 8, 3 resimden 1. Samsung Galaxy S6 Active Battery Replacement: adım 8, 3 resimden 2. Samsung Galaxy S6 Active Battery Replacement: adım 8, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Once the glass is off, you will see a small clip covering the screen connection to the motherboard at the top of the phone. Use tweezers to grab the clip by the crease on its side and pull it out.
  9. Samsung Galaxy S6 Active Battery Replacement: adım 9, 1 resimden 1.
    • Undo the screen connection with a plastic tool.
  10. Samsung Galaxy S6 Active Battery Replacement: adım 10, 1 resimden 1.
    • Remove the display assembly (LCD and Digitizer).
  11. Samsung Galaxy S6 Active Battery Replacement, Battery: adım 11, 2 resimden 1. Samsung Galaxy S6 Active Battery Replacement, Battery: adım 11, 2 resimden 2.
    • Use the Phillips Head Screwdriver sized PH000 to remove the sixteen 4mm screws from the frame.
  12. Samsung Galaxy S6 Active Battery Replacement: adım 12, 1 resimden 1.
    • Put a little pressure on the top, on the bottom, and on the sides of the phone to separate the rear case.
    • You will hear the clips start undoing themselves.
  13. Samsung Galaxy S6 Active Battery Replacement: adım 13, 2 resimden 1. Samsung Galaxy S6 Active Battery Replacement: adım 13, 2 resimden 2.
    • Once all the clips have popped, pull out the rear case to separate it from the frame with the battery.
    • The battery will be on the back side of this frame.
  14. Samsung Galaxy S6 Active Battery Replacement: adım 14, 1 resimden 1.
    • Insert a plastic opening tool on the side of the frame and pull out the battery.
  15. Samsung Galaxy S6 Active Battery Replacement: adım 15, 2 resimden 1. Samsung Galaxy S6 Active Battery Replacement: adım 15, 2 resimden 2.
    • Remove the battery from the frame.
Sonuç
After completing this guide, calibrate your newly-installed battery.
42 farklı kişi bu kılavuzu tamamladı.
Lucia Valbuena
2.463 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-5, Sullivan Spring 2017 USF Tampa, Team 1-5, Sullivan Spring 2017 üyesi
USFT-SULLIVAN-S17S1G5
3 Üyeler
25 adet Kılavuz yazıldı
20 Yorum
thank you for the information on how to dissemble this device Samsung Galaxy S6 Active
Eleyson Cubias - Yanıt
You have GOT to be kidding me....... major surgery to just remove power so that I can reboot the phone. Guess I will just have to wait until all the battery power runs out. 2 or 3 days? Uggghhhhhhhhh
Joe Besta - Yanıt
You can perform a forced reboot manually. Simultaneously hold down the volume down button and the power button for 10-20 seconds. This will reboot your phone without losing anything.
Kirk Baker - Yanıt
Looks like the difficult part is the removal of the LCD assembly. What type of adhesive can be used on the LCD screen to glue back on phone?
Francisco Roque - Yanıt
Never &&^&^$^ answer…
cristhian cruz - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 15
Son 30 gün: 73
Her zaman: 64,976
