Ana içeriğe geç
Samsung Galaxy S6 Active Display Assembly Replacement
Lucia Valbuena
Lucia Valbuena ve 3 diğer katkıda bulunanlar
En son May 7, 2024 tarihinde güncellendi
30 dakika
Orta
This guide instructs you to remove the Display Assembly, which consists of the LCD and the Digitizer. After removing this assembly, you will be able to access other parts of your phone as well.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Samsung Galaxy S6 Active Display Assembly Replacement, SIM Card: adım 1, 2 resimden 1. Samsung Galaxy S6 Active Display Assembly Replacement, SIM Card: adım 1, 2 resimden 2.
    • Insert your fingernail or a plastic opening tool into the pivot on the side of the SIM tray.
    • Pry open the tray to get it out of the socket.
  2. Samsung Galaxy S6 Active Display Assembly Replacement: adım 2, 1 resimden 1.
    • Remove the SIM tray with SIM card from the phone.
  3. Samsung Galaxy S6 Active Display Assembly Replacement, Display Assembly: adım 3, 3 resimden 1. Samsung Galaxy S6 Active Display Assembly Replacement, Display Assembly: adım 3, 3 resimden 2. Samsung Galaxy S6 Active Display Assembly Replacement, Display Assembly: adım 3, 3 resimden 3.
    • Heat the front face (sides, top, bottom) of the phone with the iOpener, a hair dryer, or a heat gun for 60 seconds to loosen the adhesive around the edge of the glass.
    • If using an iOpener, heat it in a microwave for thirty seconds.
  4. Samsung Galaxy S6 Active Display Assembly Replacement: adım 4, 1 resimden 1.
    • Attach a suction cup to the lower half of the screen.
  5. Samsung Galaxy S6 Active Display Assembly Replacement: adım 5, 2 resimden 1. Samsung Galaxy S6 Active Display Assembly Replacement: adım 5, 2 resimden 2.
    • Using the suction cup, pull gently the lower half of the panel.
    • If you pull too hard you may break the display. If you still feel resistance repeat Step 3, leaving the iOpener on longer.
  6. Samsung Galaxy S6 Active Display Assembly Replacement: adım 6, 3 resimden 1. Samsung Galaxy S6 Active Display Assembly Replacement: adım 6, 3 resimden 2. Samsung Galaxy S6 Active Display Assembly Replacement: adım 6, 3 resimden 3.
    • Once you’ve opened a large enough gap, insert a plastic tool at the bottom, between the glass and the rest of frame of the phone.
    • Slide the plastic opening tool around the screen, prying the display gently away from the body
  7. Samsung Galaxy S6 Active Display Assembly Replacement: adım 7, 1 resimden 1.
    • Pull the lower half of the screen screen with the suction cup while holding down the frame of the phone to separate both components.
    • Only lift the lower part of the screen. It is connected with a clip to the top of the motherboard and can rip off if you pull too hard.
  8. Samsung Galaxy S6 Active Display Assembly Replacement: adım 8, 3 resimden 1. Samsung Galaxy S6 Active Display Assembly Replacement: adım 8, 3 resimden 2. Samsung Galaxy S6 Active Display Assembly Replacement: adım 8, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Once the glass is off, you will see a small clip covering the screen connection to the motherboard at the top of the phone. Use tweezers to grab the clip by the crease on its side and pull it out.
  9. Samsung Galaxy S6 Active Display Assembly Replacement: adım 9, 1 resimden 1.
    • Undo the screen connection with a plastic tool.
  10. Samsung Galaxy S6 Active Display Assembly Replacement: adım 10, 1 resimden 1.
    • Remove the display assembly (LCD and Digitizer).
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Lucia Valbuena
2.463 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-5, Sullivan Spring 2017 USF Tampa, Team 1-5, Sullivan Spring 2017 üyesi
USFT-SULLIVAN-S17S1G5
3 Üyeler
25 adet Kılavuz yazıldı
6 Yorum
Great guide but I don't think its difficult, one of the easier repairs out there.
johnwkrebs - Yanıt
Okay, well, the hairdryer didn’t work. Or maybe that suction cup might help lift a screen that *isn’t* shattered…?
Ah, well. At least the guide was free and the screen kit was cheap; now it’s all just trash.
skyblueandblack - Yanıt
Suction cup does not work on a cracked screen. You will loose vacuum via the gaps in the cracks. Also be patient with the hair dryer. You must not rush that process. The idea is to heat the edge of the glass so that the glue strip under will melt or get soft enough to pull lose. Not to hot and not to cold. To hot and you damage the phone. To cold and the glue wont melt. It must be hot enough to touch with your finger for a few seconds before burning you. Then keep heating all the way around as you work IF you are working slow. The glue will harden if it cools done. I broke many screens before the process clicked in my mind. Now I realise how easy it was altogether.
Good luck
Brian Smith -
So we got it apart, which wasnt hard, just a pain! But yeah in the directions it says to put back together just reverse disrecyions. Umm yeah thats NOT working, i can NOT get the %#*@ screen connector reconnected. I've been trying for the 2 hours and it's not working! How am I suppose to line it up? And is it suppose to just clip together? What am I missing??? Please help!
Christina Ricciardi - Yanıt
How do you reseal the screen? Do new screens come with glue to reattach the screens with?
Hyrum Tripp - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 20
Her zaman: 7,239
