Ana içeriğe geç
Samsung Galaxy S8 Active Camera Glass Replacement
Neye ihtiyacın var
  1. Samsung Galaxy S8 Active Camera Glass Replacement, Camera Glass: adım 1, 1 resimden 1.
    • Lay phone face down and remove any coverings to the camera area. This way there are no obstructions to the repair area.
  2. Samsung Galaxy S8 Active Camera Glass Replacement: adım 2, 1 resimden 1.
    • Turn on the heat gun and hold it 3-4 inches from the glass for 5 seconds, waving it gently over the area to evenly distribute heat.
    • It may be helpful to keep the case on during this step, to avoid excessively heating the adhesive of the back panel.
  3. Samsung Galaxy S8 Active Camera Glass Replacement: adım 3, 2 resimden 1. Samsung Galaxy S8 Active Camera Glass Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Gently remove the glass with tweezers.
    • If the adhesive is still strong, utilize the heat gun for another 3-5 seconds, waving it over the area.
  4. Samsung Galaxy S8 Active Camera Glass Replacement: adım 4, 1 resimden 1.
    • Check the surface for any residue or broken glass from previous cover.
  5. Samsung Galaxy S8 Active Camera Glass Replacement: adım 5, 1 resimden 1.
    • Center the new glass over the camera lens and lower it to the phone, careful to not scratch the exposed camera lens.
  6. Samsung Galaxy S8 Active Camera Glass Replacement: adım 6, 1 resimden 1.
    • Press gently on the perimeter of the glass to ensure a strong bond between the glass and the phone, but not pressing hard enough to break the glass.
Sonuç
The device should be in working condition after the last step. Be sure to turn on the phone and verify to see if there are any obstructions to the camera view caused by the new glass covering.
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
Did you use the rear camera glass from Amazon that you've put a link to under parts? The Amazon seller has stated that it doesn't fit the Samsung S8 Active so unsure whether to purchase. Thanks
Natasha Wightman - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 18
Her zaman: 871
