Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Videoya Genel Bakış
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Switch off your phone.
Use an iOpener to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes. You might want to repeat this step several times during the back cover removal.
In the following steps, you'll be cutting through the adhesive securing the back cover.
You'll be slicing through the adhesive in the areas shown:
Thick portions of adhesive
Thin areas of adhesive
Avoid prying or slicing in this area, to protect the fingerprint sensor flex cable.
Press a suction cup onto the back cover.
Lift the back cover's bottom edge with your suction cup, opening a slight gap between the back cover and the frame.
Insert an opening pick in the gap and slide it to the bottom right corner.
Insert a second opening pick and slide it to the bottom left corner.
Insert a third opening pick at the bottom end of the phone. This opening pick stays there during the rear glass removal procedure to prevent the adhesive from resealing.
Start to slide the tip of the opening pick from the bottom left corner along the side of the S9 Plus.
Leave the opening pick in its place after you cut the adhesive half way up the left side of the phone.
Slide the opening pick from the bottom right corner half way up the frame and leave it there.
Insert a fourth opening pick at the right side of the frame and slide it to the top right corner.
Slide a fifth opening pick along the left side of the phone to the top left corner.
Use the opening pick to cut the remaining adhesive under the upper part of the rear glass.
Carefully lift the side of the rear glass where the volume button is located.
Use the edge of a spudger to pry up and disconnect the fingerprint sensor flex cable.
Insert an opening pick under the right side of the plastic cover containing the NFC antenna and charging coil.
Flip the opening pick sideways to lift the cover out of its plastic clips.
Work your way around the plastic cover, prying up to release the remaining clips.
Remove the plastic cover containing the NFC antenna and the charging coil.
Use the flat end of a spudger to pry up and disconnect the battery flex cable.
Use the flat end of a spudger to disconnect the display flex cable.
Prepare an iOpener and apply it to the display for at least two minutes to loosen the adhesive beneath.
Lay overlapping strips of clear packing tape over the display until the whole face is covered.
This will keep glass shards contained and provide structural integrity when prying and lifting the display.
Once the screen is warm to the touch, apply a suction cup to the upper edge of the phone.
Insert an opening pick in the gap and start to cut the adhesive by sliding it to the top left corner.
Insert another opening pick and slide it to the top right corner of the phone.
Insert a third opening pick to prevent the adhesive from resealing during the display removal.
Start to slide the right opening pick half way down the side of the frame to cut the adhesive.
Slide the left opening pick half way down the frame and leave it in place.
Insert a fourth opening pick at the left side of the frame and slide it down to the bottom left corner to cut the adhesive.
Insert a fifth opening pick on the right side and slide it down.
Slide around the bottom right corner and cut the remaining adhesive on the bottom end of the display.
Once you cut the adhesive on all sides of the phone you can slowly lift the display upwards and remove it.
44 farklı kişi bu kılavuzu tamamladı.
10 Yorum
bonsoir
où puis-je trouver la coque arrière du s9 plus? puisque le mien est endomagé.
boubajinior@gmail.com
Bonjour,
voici le lien sur l’article en question : ++Galaxy S9+ Rear Glass Panel/Cover
et voici le lien sur le tutoriel pour l’échange : ++https://www.ifixit.com/Guide/Samsung+Gal...
how to change sansung galaxy S9 plus (screen) LCD flex belt?
