Ana içeriğe geç
Neye ihtiyacın var
Videoya Genel Bakış
Bu teardown bir tamir kılavuzu değildir. Samsung Galaxy S9 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Samsung Galaxy S9 Teardown, Teardown: adım 1, 3 resimden 1. Samsung Galaxy S9 Teardown, Teardown: adım 1, 3 resimden 2. Samsung Galaxy S9 Teardown, Teardown: adım 1, 3 resimden 3.
    • This smaller version of the S9+ gets a big hardware upgrade. Let's take a look:
    • Notchless 5.8" AMOLED Display with resolution of 2960 × 1440 (~570 ppi)
    • Qualcomm Snapdragon 845 or Samsung’s own Exynos 9810, depending on location
    • 12 MP OIS dual-aperture main camera—f/1.5 and f/2.4 modes—plus an 8 MP selfie cam
    • Headphone jack and microSD slot
    • IP68 water/dust-proofing rating
    • Android 8.0 Oreo
  2. Samsung Galaxy S9 Teardown: adım 2, 3 resimden 1. Samsung Galaxy S9 Teardown: adım 2, 3 resimden 2. Samsung Galaxy S9 Teardown: adım 2, 3 resimden 3.
    • We start with a sneak peek—X-ray intel provided by our co-conspirators at Creative Electron.
    • If you liked the S8, we've got good news—Samsung agrees with you. The design seems almost totally unchanged, save for the new (and better) fingerprint sensor location.
    • Our S9 cozies up to its S8 ancestor on the left (reassembled from our 2017 teardown) and its S9+ sibling on the right (still sore from our teardown last weekend).
    • Props to Samsung for keeping the headphone jack and expandable storage, all while maintaining IP68 protection.
    • Are these things new? No. Are they still good? We say yes.
  3. Samsung Galaxy S9 Teardown: adım 3, 3 resimden 1. Samsung Galaxy S9 Teardown: adım 3, 3 resimden 2. Samsung Galaxy S9 Teardown: adım 3, 3 resimden 3.
    • Getting inside a Galaxy phone hasn't gotten any easier lately, but at least the procedure is familiar:
    • Step 1: get it hot.
    • Step 2: add more heat.
    • Step 3: suction and slice, and don't hit that fingerprint sensor cable that you can't see.
    • You've probably heard us complain about this before, so we'll just add this: yes it's risky and tedious, but at least if you crack the back glass, you stand a chance of being able to replace it economically. (Our favorite fruit company is still working on that one.)
  4. Samsung Galaxy S9 Teardown: adım 4, 3 resimden 1. Samsung Galaxy S9 Teardown: adım 4, 3 resimden 2. Samsung Galaxy S9 Teardown: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    iFixit Adhesive Remover
    $19.99
    Satın Al
  5. Samsung Galaxy S9 Teardown: adım 5, 3 resimden 1. Samsung Galaxy S9 Teardown: adım 5, 3 resimden 2. Samsung Galaxy S9 Teardown: adım 5, 3 resimden 3.
    • Next we turn our attention to the brains of the phone, and after removing a few friendly Phillips screws, the motherboard slides free.
    • If this board already looks a bit worse for wear, that's because we previously removed the EMI shields for our video teardown. Give yourself a pat on the back if you noticed!
    • Near the top of the board we get a look at the S9's new heart rate and blood pressure sensors, a step up from the standard heart rate sensor seen on many phones.
    • This new blood pressure hardware works alongside a Samsung and UCSF co-developed research app to give users info about stress levels and blood pressure.
    • Say hello to Dr. Bixby.
  6. Samsung Galaxy S9 Teardown: adım 6, 3 resimden 1. Samsung Galaxy S9 Teardown: adım 6, 3 resimden 2. Samsung Galaxy S9 Teardown: adım 6, 3 resimden 3.
    • Compared to some flagships, the S9 has twice the f-stops and half the sensors.
    • Not shown: Samsung's highly touted 2 Gbit LPDDR4 DRAM, layered right underneath the image sensor.
    • Shown: Some other mystery chips.
    • RD938 likely OIS driver
    • STMicroelectronics L2G2IS 2-axis OIS gyroscope
    • GigaDevice GD25LQ32 32 Mb serial flash
  7. Samsung Galaxy S9 Teardown: adım 7, 2 resimden 1. Samsung Galaxy S9 Teardown: adım 7, 2 resimden 2.
    • We want to try out the S9's new dual aperture, but using the camera app seems a little too conventional.
    • After a bit of disassembly, a spudger seems to do the trick instead.
    • This may seem goofy, but the S9 really will have a small actuator that mechanically opens and closes the aperture—a mechanical bit that can fail.
    • Removing the lens also reveals the image sensor. Taking a closer look we see...yep that's an image sensor. Maybe some X-rays can show us that DRAM...
  8. Samsung Galaxy S9 Teardown: adım 8, 1 resimden 1.
    • Lets take a look at the chips that power all that fancy hardware:
    • Samsung K3UH5H5OMM-AGCJ 32 Gb (4 GB) LPDDR4X DRAM, layered over a Qualcomm Snapdragon 845
    • Toshiba THGAF8G9T43BAIR 64 GB UFS (NAND flash + controller)
    • Avago AFEM-9096 front end module
    • Qualcomm Aqstic WCD9341 audio codec
    • Maxim MAX77705F PMIC
    • Skyworks SKY13716-1 low band front end module
    • IDT P9320S wireless power receiver likely similar to the P9320
  9. Samsung Galaxy S9 Teardown: adım 9, 1 resimden 1.
    • There's another gathering of integrated circuits on the flip side:
    • Murata KM7N07016 Wi-Fi/Bluetooth module
    • NXP PN80T NFC controller
    • Qualcomm PM845 (likely PMIC)
    • Qualcomm SDR845 RF transceiver
    • Hard to make out, but we think this is likely the same Skyworks SKY78160-11 front-end module we found in the S9+
    • Qualcomm PM8005 PMIC
    • Qualcomm QDM3870 high-band diversity front-end module
  10. Samsung Galaxy S9 Teardown: adım 10, 2 resimden 1. Samsung Galaxy S9 Teardown: adım 10, 2 resimden 2.
    • IC Identification, pt. 2:
    • Maxim Integrated MAX98512 audio amplifier (1st one marked is unconfirmed)
    • Samsung S2MPB02 camera power management
    • Samsung S2MPB03 camera power management
    • Samsung S2DOS05 display power management
    • Qualcomm D5319 mid-band diversity front-end module
    • RDA Microelectronics RDA6213N FM transceiver (likely)
    • Qualcomm QET4100 envelope tracker
  11. Samsung Galaxy S9 Teardown: adım 11, 2 resimden 1. Samsung Galaxy S9 Teardown: adım 11, 2 resimden 2.
    • IC Identification, pt. 3:
    • NXP Semiconductor PCAL6524 24-bit I/O expander
    • ON Semiconductor FPF3688UCX load switch
    • Vishay DG2730 2-port, 480 Mbps USB 2.0 DPDT analog switch
    • ON Semiconductor FAN48618BUC53X 1 A boost regulator
    • Richtek RT8010GQW 1 A step-down DC-DC converter
    • Texas Instruments boost converter (likely)
    • NXP Semiconductor NCX2200 comparator
  12. Samsung Galaxy S9 Teardown: adım 12, 2 resimden 1. Samsung Galaxy S9 Teardown: adım 12, 2 resimden 2.
    • IC Identification, pt. 4 (sensors):
    • STMicroelectronics LSM6DSL 3-axis accelerometer/gyroscope
    • AKM Semiconductor AK09916C 3-axis electronic compass
    • STMicroelectronics LPS22HB pressure sensor
    • heart rate sensor
    • Ablic (formerly Seiko Instruments) S-5712CCDL1-I4T1U hall sensor
  13. Samsung Galaxy S9 Teardown: adım 13, 1 resimden 1.
    • From "S9" to "See ya later!" This teardown is toast!
    • We skipped a lot of the familiar details—if you haven't already, you can get the deeper dive into some similar Samsungs like the S9+, S8, and S8+.
  14. Son Düşünceler
    • Many components are modular and can be replaced independently.
    • The battery replacement is technically possible, but accessing it is an unnecessary challenge.
    • Glued-down glass both front and back means greater risk of breakage, and makes repairs difficult to start.
    • Screen repairs require a lot of disassembly while battling tough adhesive.
    Onarılabilirlik Puanı
    4
    Onarılabilirlik 10 üzerinden 4
    (10 en kolay onarılabileni)
16 Yorum
Hello:
So, no radio on this model either?
Thanx for another great video and teardown explanation : )
Héctor Gonçalvez - Yanıt
that was perfect
mohsen - Yanıt
Can you identify and break apart the RF front end please
Mikey W - Yanıt
Can the outer glass be replaced without replacing the entire lce
lovemolai - Yanıt
Technically but not worth the
Blank -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 17
Son 7 gün: 101
Son 30 gün: 429
Her zaman: 143,893
