Ana içeriğe geç
Samsung Galaxy Tab A 10.1 Charging Port Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab A 10.1 Charging Port Replacement, Back Panel: adım 1, 2 resimden 1. Samsung Galaxy Tab A 10.1 Charging Port Replacement, Back Panel: adım 1, 2 resimden 2.
    • Have the front of the device facing you.
    • Begin near one of the curved edges of the device (see photo two for visual example).
    • Place a plastic opening tool between the front and back panels.
    • If a plastic opening tool doesn’t work, using a metal spudger may work, but it may damage the plastic on the device.
    • Remember to remove the micro SD card (if present) before you begin.
  2. Samsung Galaxy Tab A 10.1 Charging Port Replacement: adım 2, 2 resimden 1. Samsung Galaxy Tab A 10.1 Charging Port Replacement: adım 2, 2 resimden 2.
    • Once the plastic opening tool is fully inserted, wedge it around the device’s edges to separate the panels.
    • Lift the back panel off of the device.
    • The back panel will make a clicking noise while being lifted off of the device.
  3. Samsung Galaxy Tab A 10.1 Charging Port Replacement, Disconnecting the battery: adım 3, 1 resimden 1.
    • Remove the adhesive film and flip up the retaining flap on the ZIF battery connector.
    • Slide the orange battery ribbon cable out of the ZIF connector.
  4. Samsung Galaxy Tab A 10.1 Charging Port Replacement: adım 4, 2 resimden 1. Samsung Galaxy Tab A 10.1 Charging Port Replacement: adım 4, 2 resimden 2.
    • Remove the adhesive film, lift the retaining tab and withdraw the white speaker ribbon.
  5. Samsung Galaxy Tab A 10.1 Charging Port Replacement: adım 5, 3 resimden 1. Samsung Galaxy Tab A 10.1 Charging Port Replacement: adım 5, 3 resimden 2. Samsung Galaxy Tab A 10.1 Charging Port Replacement: adım 5, 3 resimden 3.
    • Lift the retaining tab and withdraw the black LCD ribbon.
  6. Samsung Galaxy Tab A 10.1 Charging Port Replacement, Battery removal: adım 6, 2 resimden 1. Samsung Galaxy Tab A 10.1 Charging Port Replacement, Battery removal: adım 6, 2 resimden 2.
    • Using a Phillips #000 screwdriver, remove the ten 4 mm screws around the battery.
    • Slide a plastic opening tool under the bottom of the battery close to the speakers and lift up.
    • The large rectangular white and black piece is the entire battery. Be careful not to puncture it.
  7. Samsung Galaxy Tab A 10.1 Charging Port Replacement, Motherboard: adım 7, 3 resimden 1. Samsung Galaxy Tab A 10.1 Charging Port Replacement, Motherboard: adım 7, 3 resimden 2. Samsung Galaxy Tab A 10.1 Charging Port Replacement, Motherboard: adım 7, 3 resimden 3.
    • Flip up the two ZIF connectors on the motherboard using the plastic opening tool.
    • Slide the orange ribbon cables out of the ZIF connectors.
    • Remove the front-facing camera.
  8. Samsung Galaxy Tab A 10.1 Charging Port Replacement: adım 8, 1 resimden 1.
    • Disconnect the headphone jack from the motherboard.
    • Use a Phillips # 000 to remove six 4mm screws.
  9. Samsung Galaxy Tab A 10.1 Charging Port Replacement: adım 9, 2 resimden 1. Samsung Galaxy Tab A 10.1 Charging Port Replacement: adım 9, 2 resimden 2.
    • Lodge the plastic opening tool under and lift the motherboard out of the tablet.
    • Be careful not to snag any connectors.
    • Remove the metal bracket that was underneath the charging port and set aside.
  10. Samsung Galaxy Tab A 10.1 Charging Port Replacement, Charging Port: adım 10, 1 resimden 1.
    • Place desoldering braid on one of four holes at top back of motherboard.
    • Place soldering iron on top of the desoldering braid on the gray part of hole to lift solder. If confused here’s a reference.
    • If desoldering braid gets covered with solder and won’t lift anymore, just use a new part of the solder wick.
    • If you're struggling to desolder the charging port, use a heat gun to warm up the entire board. There are a set of tiny square contacts under the charging port that can move around while heating the area. They must be put back if they move.
    • Soldering iron will be very hot and can both burn your hand and possibly damage the device. Lay the motherboard down and do not hold the board while you solder (despite the image.)
  11. Samsung Galaxy Tab A 10.1 Charging Port Replacement: adım 11, 1 resimden 1.
    • Follow same steps on other three holes.
    • Lift small gray metal piece from the motherboard.
Sonuç
To reassemble your device, place a new metal piece where old one was and solder it to the motherboard in the four holes on the opposite side of the motherboard.
15 farklı kişi bu kılavuzu tamamladı.
Isabella Li
2.376 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S15-G6, Livingston Fall 2017 Cal Poly, Team S15-G6, Livingston Fall 2017 üyesi
CPSU-LIVINGSTON-F17S15G6
4 Üyeler
26 adet Kılavuz yazıldı
13 Yorum
It is impossible to unmount the old damaged USB-Interface this way. Beside the four solder-points ist is also soldered to 5 extremely small points on the motherboards opposite side. These are SMD-mounted contacts and in my case trying to unsolder them damaged the motherbords layout.
Lutz Christoph - Yanıt
I was able to desolder it with a hot air rework station + soldering iron without damaging the pcb then using a wick cut at an angle + the heat gun to clean the mounting holes you must clean then fully so the new part will mount flush.
Also take care with resoldering the new connector not to bridge the pins on the usb port.
cusbrar2 - Yanıt
what is the model of USB connector here? I would like to buy in advance before opening
Алексей Хейдоров - Yanıt
These instructions are really incomplete. In addition to the 4 through-hole points mentioned, there are also 2 large ground pads under the connector, and 7 tiny surface-mount pins on the back. Removing this port pretty much requires low-temp (chip-quick) solder or a hot-air rework station. Soldering it back on with only an iron proved quite difficult - hot-air rework station highly recommended. This took me about an hour, and I’ve been soldering (hobby mostly) for the better part of 30 years.
Also, there’s no reason to remove the battery to change the charging port. The motherboard can be removed without removing the battery. And really, the cameras should be disconnected too, rather than leaving them dangling by their ribbon cables.
Nathan Lewis - Yanıt
Where can you buy the exact replacement USB port
yafecker - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 120
Son 30 gün: 506
Her zaman: 70,649
