Ana içeriğe geç
Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement
Joy Harris
Joy Harris ve 4 diğer katkıda bulunanlar
En son May 7, 2024 tarihinde güncellendi
25 - 35 dakika
Orta
Broken speakers prevent your tablet from producing quality sound or any sound at all. Removing the speakers may require an iOpener or a heat gun. Check out this iOpener guide for instructions on how to use it.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement, Screen: adım 1, 2 resimden 1. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement, Screen: adım 1, 2 resimden 2.
    • Apply the heat gun around the edges of the tablet to melt the adhesive glue.
    • Do not allow the gun to remain still for more than two seconds, so that you do not melt the plastic around the screen.
    • If you do not have access to a heat gun, you may also use an iOpener or a hair dryer. Refer to the iOpener guide for extra help.
  2. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: adım 2, 2 resimden 1. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: adım 2, 2 resimden 2.
    • Apply the suction to the bottom or top right corner.
    • Use the plastic opening tool at several points around the screen while the suction is being applied to pop the screen out.
  3. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: adım 3, 1 resimden 1.
    • Once the screen is detached, open the tablet like a book.
    • Gently open the tablet, and do not pull the pieces apart since you can risk damaging the orange ribbon cable.
  4. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using the precision tweezers, remove the silver tape that is holding the orange ribbon cable connecting the two pieces.
  5. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: adım 5, 1 resimden 1.
    • Using the precision tweezers, remove the small press-fit connector from the body of the tablet.
  6. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement, Screws: adım 6, 2 resimden 1. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement, Screws: adım 6, 2 resimden 2.
    • Using the Philips #000 screwdriver, remove the seventeen 2.74 mm screws around the edges.
    • Remove the two 2.74 mm black screws in the middle of the tablet with the Philips #000 screwdriver.
    • Put the screws on a magnetic project mat or in a container so that you do not lose them.
  7. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: adım 7, 3 resimden 1. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: adım 7, 3 resimden 2. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: adım 7, 3 resimden 3.
    • Take the plastic opening tool around the tablet to remove the motherboard from the device.
  8. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement, Speaker: adım 8, 2 resimden 1. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement, Speaker: adım 8, 2 resimden 2.
    • Locate the speakers towards the bottom.
    • For the speaker on the left, use the plastic opening tool to lift up the press-fit connector.
  9. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: adım 9, 2 resimden 1. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: adım 9, 2 resimden 2.
    • Apply the iOpener to the magnet to loosen the adhesive glue.
    • Refer to the iOpener guide for more help.
    • If you do not have access to an iOpener, you may also use a heat gun or a hair dryer.
  10. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: adım 10, 1 resimden 1.
    • Using the precision tweezers, remove the speaker.
  11. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: adım 11, 2 resimden 1. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: adım 11, 2 resimden 2.
    • For the speaker on the right, use the plastic opening tool to lift up the press-fit connector.
    • Using the precision tweezers, detach the orange cable.
  12. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: adım 12, 1 resimden 1.
    • Pull the orange ribbon cable out of the ZIF connector using the precision tweezers.
    • Be gentle so that you do not damage the orange ribbon cable.
  13. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: adım 13, 1 resimden 1.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Joy Harris
826 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G4, Sullivan Spring 2017 USF Tampa, Team S3-G4, Sullivan Spring 2017 üyesi
USFT-SULLIVAN-S17S3G4
3 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 29
Her zaman: 1,327
