Ana içeriğe geç
Samsung Galaxy Tab S3 Daughterboard Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab S3 Daughterboard Replacement, Display: adım 1, 1 resimden 1.
    • To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device. Alternatively you can use a heat gun to loosen the adhesive.
    • Leave the iOpener on edge for two minutes.
    • Be careful not to burn yourself while handling the hot iOpener. For more information on the iOpener, use the iOpener Instructions Guide.
    There is no reason to remove the screen while replacing a battery.
    Nick Youngstrom - Yanıt
    Agreed , just remove back and warm up. Dont remove screen, is $220 to replace off ebay.
    Phenix City - Yanıt
  2. Samsung Galaxy Tab S3 Daughterboard Replacement: adım 2, 1 resimden 1.
    • Place a suction cup near edge that you heated up with the iOpener.
    • Press down on the suction cup to create a seal, and pull up with force to create a separation between the display and the midframe.
    • Use an opening tool to split apart the glass panel from the midframe.
    • Be careful to not break the glass when prying from the frame.
    Bonjour, pour moi il est IMPÉRATIF d’opérer l’ouverture par le bord droit comme indiqué sur le tuto car de l’autre coté les nappes du LCD ne sont qu’à 3mm du bord et peuvent etre abimée comme je l’ai fait lors du décollage.
    Jacques Barreau - Yanıt
  3. Samsung Galaxy Tab S3 Daughterboard Replacement: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    Plastic Cards
    $2.99
    Satın Al
    • As you continue along the edge using the opening tool, use a plastic card to keep the glass separate from the midframe.
    • You can also use multiple opening picks instead of a plastic card.
    For this part I recommend to insert the tools only on top, bottom and right side. Then lift the screen as shown in the pictures in step 4. The left side has the light ribbons for the display too close to the edge and they are really thin. I just broke the four of them in my screen :(
    Moisés Jover - Yanıt
  4. Samsung Galaxy Tab S3 Daughterboard Replacement: adım 4, 3 resimden 1. Samsung Galaxy Tab S3 Daughterboard Replacement: adım 4, 3 resimden 2. Samsung Galaxy Tab S3 Daughterboard Replacement: adım 4, 3 resimden 3.
    • Pull off the glass panel using the suction cup.
    • As you remove the glass panel, be careful not to tear the ribbon connecting the motherboard to the display.
    • Carefully disconnect the ribbon cable connecting the display assembly to the motherboard. You can disconnect this ribbon from either end.
  5. Samsung Galaxy Tab S3 Daughterboard Replacement, Rear glass panel: adım 5, 2 resimden 1. Samsung Galaxy Tab S3 Daughterboard Replacement, Rear glass panel: adım 5, 2 resimden 2.
    • Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device.
  6. Samsung Galaxy Tab S3 Daughterboard Replacement, Battery: adım 6, 2 resimden 1. Samsung Galaxy Tab S3 Daughterboard Replacement, Battery: adım 6, 2 resimden 2.
    • Use a Phillips #000 screwdriver to unscrew the five screws securing the battery, and the twenty-two screws surrounding the midframe.
  7. Samsung Galaxy Tab S3 Daughterboard Replacement: adım 7, 1 resimden 1.
    • The midframe should snap off from the device’s motherboard.
  8. Samsung Galaxy Tab S3 Daughterboard Replacement: adım 8, 3 resimden 1. Samsung Galaxy Tab S3 Daughterboard Replacement: adım 8, 3 resimden 2. Samsung Galaxy Tab S3 Daughterboard Replacement: adım 8, 3 resimden 3.
    • Locate the ribbon running from the midframe and disconnect it from the motherboard with the flat end of a spudger.
  9. Samsung Galaxy Tab S3 Daughterboard Replacement: adım 9, 2 resimden 1. Samsung Galaxy Tab S3 Daughterboard Replacement: adım 9, 2 resimden 2.
    • Use the flat end of the spudger to pop off the connector between the battery and the motherboard.
  10. Samsung Galaxy Tab S3 Daughterboard Replacement: adım 10, 2 resimden 1. Samsung Galaxy Tab S3 Daughterboard Replacement: adım 10, 2 resimden 2.
    • Flip the midframe over and pop the battery out, making sure to slide it out from underneath the ribbon cables.
  11. Samsung Galaxy Tab S3 Daughterboard Replacement: adım 11, 1 resimden 1.
    • The battery should now be removed and detached from the device.
  12. Samsung Galaxy Tab S3 Daughterboard Replacement, Daughterboard: adım 12, 3 resimden 1. Samsung Galaxy Tab S3 Daughterboard Replacement, Daughterboard: adım 12, 3 resimden 2. Samsung Galaxy Tab S3 Daughterboard Replacement, Daughterboard: adım 12, 3 resimden 3.
    • Use a spudger to pry up four press fit connectors from the lower board containing the charging port.
  13. Samsung Galaxy Tab S3 Daughterboard Replacement: adım 13, 3 resimden 1. Samsung Galaxy Tab S3 Daughterboard Replacement: adım 13, 3 resimden 2. Samsung Galaxy Tab S3 Daughterboard Replacement: adım 13, 3 resimden 3.
    • Pry up the two coaxial cables joining the daughterboard to the motherboard.
    • Be sure to pull the white coaxial cable from the small bracket holding the wire to the daughterboard before removal.
  14. Samsung Galaxy Tab S3 Daughterboard Replacement: adım 14, 3 resimden 1. Samsung Galaxy Tab S3 Daughterboard Replacement: adım 14, 3 resimden 2. Samsung Galaxy Tab S3 Daughterboard Replacement: adım 14, 3 resimden 3.
    • Pry the daughterboard up from the midframe with a spudger.
    • Remove the daughterboard.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Austin Blakely
19.631 İtibar
53 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
136 Üyeler
17.299 adet Kılavuz yazıldı
3 Yorum
Do you need to remove the front display assembly to replace the daughterboard? From the images it appears you just have to go in through the back glass to do this job. Confused.
Grant Ormsby - Yanıt
You do, because the midframe is adhered to both the front and back. It won't come off if you just take off the back.
Flint Green -
You don't have to take screen off. Just disconnect battery.
Jake Fowler - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 45
Her zaman: 2,096
