Ana içeriğe geç
Samsung Galaxy Tab S3 Display Replacement
Neye ihtiyacın var
    1. Samsung Galaxy Tab S3 Display Replacement, Display: adım 1, 1 resimden 1.
      • To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device. Alternatively you can use a heat gun to loosen the adhesive.
      • Leave the iOpener on edge for two minutes.
      • Be careful not to burn yourself while handling the hot iOpener. For more information on the iOpener, use the iOpener Instructions Guide.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Galaxy Tab S3 Display Replacement: adım 2, 1 resimden 1.
      • Place a suction cup near edge that you heated up with the iOpener.
      • Press down on the suction cup to create a seal, and pull up with force to create a separation between the display and the midframe.
      • Use an opening tool to split apart the glass panel from the midframe.
      • Be careful to not break the glass when prying from the frame.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Galaxy Tab S3 Display Replacement: adım 3, 1 resimden 1.
      Bu adımda kullanılan alet:
      Plastic Cards
      $2.99
      • As you continue along the edge using the opening tool, use a plastic card to keep the glass separate from the midframe.
      • You can also use multiple opening picks instead of a plastic card.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung Galaxy Tab S3 Display Replacement: adım 4, 3 resimden 1. Samsung Galaxy Tab S3 Display Replacement: adım 4, 3 resimden 2. Samsung Galaxy Tab S3 Display Replacement: adım 4, 3 resimden 3.
      • Pull off the glass panel using the suction cup.
      • As you remove the glass panel, be careful not to tear the ribbon connecting the motherboard to the display.
      • Carefully disconnect the ribbon cable connecting the display assembly to the motherboard. You can disconnect this ribbon from either end.
      FixBot'a Sor
      Yorum Ekle
    5. Samsung Galaxy Tab S3 Display Replacement, Rear glass panel: adım 5, 2 resimden 1. Samsung Galaxy Tab S3 Display Replacement, Rear glass panel: adım 5, 2 resimden 2.
      • Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. If you have removed too much adhesive, you may need to apply more during the reassembly process.
7 farklı kişi bu kılavuzu tamamladı.
Jelly Romero
322 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S22-G4, Maness Spring 2018 Cal Poly, Team S22-G4, Maness Spring 2018 üyesi
CPSU-MANESS-S18S22G4
5 Üyeler
15 adet Kılavuz yazıldı
6Kılavuz Yorumları
Thank you so much, It helped me so much.
MRxROBOT - Yanıt Paylaş
What if the digitizer is ok and only the glass cover is cracked
stargazer_jbl - Yanıt Paylaş
if you need more adhesive what is the right type to buy? Want to have some on hand before I open my S3 up.
jnorr - Yanıt Paylaş
If my screen freezing exactly half, can that be the connection cable damaged.? It's look like it happens every time I touch or hold the corner where the volume and power buttons are. Never dropped it.
Lena Clark - Yanıt Paylaş
I also have the same issue
How your issue was resolved.
Ashwin - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 32
Son 30 gün: 113
Her zaman: 30,463
