Ana içeriğe geç
Samsung Galaxy View Battery Replacement
Neye ihtiyacın var
  1. Samsung Galaxy View Battery Replacement, Kickstand: adım 1, 1 resimden 1.
    • Place the device on a hard flat surface with its screen facing downwards.
    • Rotate the the kickstand so that the handle grip hole is up in the air and not touching the back of the tablet.
  2. Samsung Galaxy View Battery Replacement: adım 2, 3 resimden 1. Samsung Galaxy View Battery Replacement: adım 2, 3 resimden 2. Samsung Galaxy View Battery Replacement: adım 2, 3 resimden 3.
    • Stick the pointy end of the spudger into the circular opening of the leftmost metallic latch.
    • With the spudger still inserted, pry the spudger to the right pushing the latch opening along with it.
    • Once the latch is moved to the right, pull up on the left side of the kickstand, releasing it from the back of the tablet.
    • Repeat the previous steps for the rightmost latch, and then lift the kickstand off the back of the tablet.
  3. Samsung Galaxy View Battery Replacement, Battery: adım 3, 2 resimden 1. Samsung Galaxy View Battery Replacement, Battery: adım 3, 2 resimden 2.
    • Check the device is completely turned off.
    • Slide open the SD compartment tab, and remove the SD card to ensure all data is saved.
  4. Samsung Galaxy View Battery Replacement: adım 4, 3 resimden 1. Samsung Galaxy View Battery Replacement: adım 4, 3 resimden 2. Samsung Galaxy View Battery Replacement: adım 4, 3 resimden 3.
    • Remove the 4 screws (4 mm in length) using the Phillips #0 screwdriver.
  5. Samsung Galaxy View Battery Replacement: adım 5, 3 resimden 1. Samsung Galaxy View Battery Replacement: adım 5, 3 resimden 2. Samsung Galaxy View Battery Replacement: adım 5, 3 resimden 3.
    • Insert the plastic opening tool between the seam of the back panel and the front casing to create an initial opening.
    • Insert the metal spudger within the opening.
    • Move the metal spudger down the seam, prying the back panel open as you go.
    • Once a large enough opening is made, pry the entire back panel off with your hand.
    • You will hear loud popping from the magnetized latches. This is not causing damage to the device and will require some force to open.
  6. Samsung Galaxy View Battery Replacement: adım 6, 2 resimden 1. Samsung Galaxy View Battery Replacement: adım 6, 2 resimden 2.
    • Using the plastic opening tool, lift off the orange press-fit connector (marked with a white arrow-head) where it attaches to the motherboard.
  7. Samsung Galaxy View Battery Replacement: adım 7, 3 resimden 1. Samsung Galaxy View Battery Replacement: adım 7, 3 resimden 2. Samsung Galaxy View Battery Replacement: adım 7, 3 resimden 3.
    • Remove the 6 screws (4 mm in length) using the Phillips #0 screwdriver.
    • Remove the battery from the device.
    Si vous trouvez une batterie pour tablette Samsung Galaxy View lithium je serais acheteurs cyr.roland@bell.net merci.
    cyr.roland - Yanıt
    cyr.roland - Yanıt
    What step 7 doesn’t mention is the battery connector must be gently pulled up to unplug from the main board and when installing the new battery gently push connector back onto the main board making sure it is properly lined up
    Mark Leuck - Yanıt
Sonuç
40 farklı kişi bu kılavuzu tamamladı.
Roger Pena
1.141 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 4-5, Livingston Fall 2016 Cal Poly, Team 4-5, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S4G5
4 Üyeler
12 adet Kılavuz yazıldı
29Kılavuz Yorumları
I’m not sure if it’s the battery or the cord
Swheet - Yanıt
What size is the battery that fits into the SAMSUNG TAB VIEW?
Ricky Lee Lidel - Yanıt
Thank You, Sooo much. This guide is a true money and time saver. Worked like a gem .
Mike Rowe - Yanıt
I can't find Lithium ION 11.3 V 5700mAh battery for my Samsung Galaxy 18.4View Tablet, does anyone know where to get one?
What's difference between a 5700mAh battery and 5900mAh battery
Sue ELLEN R FONTENOT - Yanıt
Where can I find battery replacement for galaxy view
Greg Dover -
did you find out what battery goes in the Samsung view.. I need one
Jackie Everly -
Thank you, thank you. It works great.
Thanks, I replaced my battery successfully. But the problem is still not charging. The result is still the same, when plugged in, the reading is at 90% then when unplugged, it will shut off. Any ideas? Thanks
Raleigh Guevarra - Yanıt
Has anyone found where top purchase the battery for the 18 inch tablet battery?
tyoung_50 - Yanıt
Very easy to follow instructions. My Galaxy View is alive again
DocBrown - Yanıt
Im needing to replace my dc power port my guess that its this operation to remove that 1 part
Rob Smith - Yanıt
Like instructions where can I find a battery for a galaxy
Greg Dover - Yanıt
I really need help finding a battery for my Samsung Galaxy View … can anyone help?
my883_sporty - Yanıt
They sell them online but they are hard to find i just bought one on Jan 5, 2021 expected to arrive on Jan 12, 2021 also i have one for sale if interested the whole tablet… Thank you
Lakesha Griffin -
where can i buy a battery replacement for this?
ednellaurel - Yanıt
where can I find a battery replacement for the samsung galaxy view? am having an issue where it will not charge, it’s on with the power adapter plugged in but it’s at 0%.
Ange Bee - Yanıt
Anyone found a battery, yet?
Joseph Rajsky - Yanıt
Go online they have them…
Lakesha Griffin -
Bought this, and loved it. Perfect for reading books.
However, I am highly !#^&@@, that just a couple of years old, I cannot find a battery. Samsung has lost our business. &&^&^$^ ridiculous!
Go online that's where i bought mines from…
Lakesha Griffin -
I order minds offline on Jan 5, 2021
Lakesha Griffin - Yanıt
I order my battery for the Samsung Galaxy view table offline on Jan 5, 2021 expected to be here on Jan 19, 2021
If anyone is interested in purchasing a new one i have one if your intrested thank you….
I have two batteries My main board is toast I think wont charge the batteries. I even replaced the charger port. I have two of those as well. I also have two charger cables. So far my View is dead and these changes did not help. I will sell the parts if you want them.
Lori Marr - Yanıt
I want them! How can I get them? Battery for view?
Gina LaBorde -
What is the battery model. I need a replacement for the view 18.5 tablet?
Gina LaBorde - Yanıt
Amazon lists 5 or 6 compatible batteries for the sm t670 View. Not cheap.
Bill Herbert - Yanıt
I went to Best Buys and they can get a battery and the cost in Nova Scotia, Canada is $200. I didn’t ask the price to have it installed.
Sheila Flemming - Yanıt
Easy fix, ordered the battery from Ebay, about $80 and a 20 minute swap out and I have a new View!
Wayne Tilka - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 16
Son 30 gün: 83
Her zaman: 26,368
