Ana içeriğe geç
Samsung Galaxy Watch3 Motherboard Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Watch3 Motherboard Replacement, Unfasten the back cover screws: adım 1, 1 resimden 1.
    • Before starting repairs, take your watch off the charger and power it down.
    • Use a Tri-point Y00 driver to unfasten the four screws on the back of the watch.
    • Don’t worry about removing the screws, they will stay in place in the back cover.
  2. Samsung Galaxy Watch3 Motherboard Replacement, Wedge open the back cover: adım 2, 2 resimden 1. Samsung Galaxy Watch3 Motherboard Replacement, Wedge open the back cover: adım 2, 2 resimden 2.
    • Insert an opening tool between the back cover and the metal housing.
    • Twist the opening tool to create a wider gap.
    • Don't fully remove the back cover just yet. The sensor flex cable is still connected to the motherboard.
  3. Samsung Galaxy Watch3 Motherboard Replacement, Disconnect the sensor flex cable: adım 3, 3 resimden 1. Samsung Galaxy Watch3 Motherboard Replacement, Disconnect the sensor flex cable: adım 3, 3 resimden 2. Samsung Galaxy Watch3 Motherboard Replacement, Disconnect the sensor flex cable: adım 3, 3 resimden 3.
    • Lay the watch face down.
    • Carefully lift the back cover up from the edge with the buttons to access the sensor connector.
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
  4. Samsung Galaxy Watch3 Motherboard Replacement, Remove the back cover: adım 4, 2 resimden 1. Samsung Galaxy Watch3 Motherboard Replacement, Remove the back cover: adım 4, 2 resimden 2.
    • Remove the back cover.
    • Make sure the rubber gasket (marked red) is undamaged. If damaged replace it with a new one during reassembly to maintain proper water resistance.
  5. Samsung Galaxy Watch3 Motherboard Replacement, Unplug the three connectors: adım 5, 3 resimden 1. Samsung Galaxy Watch3 Motherboard Replacement, Unplug the three connectors: adım 5, 3 resimden 2. Samsung Galaxy Watch3 Motherboard Replacement, Unplug the three connectors: adım 5, 3 resimden 3.
    • Use the flat end of a spudger to disconnect the flex cables of the side buttons, the display and the hall sensor.
  6. Samsung Galaxy Watch3 Motherboard Replacement, Unfasten the motherboard screw: adım 6, 1 resimden 1.
    • Remove the Phillips #00 screw.
  7. Samsung Galaxy Watch3 Motherboard Replacement, Remove the motherboard: adım 7, 2 resimden 1. Samsung Galaxy Watch3 Motherboard Replacement, Remove the motherboard: adım 7, 2 resimden 2.
    Bu adımda kullanılan alet:
    • The motherboard is held in place by two small plastic clips.
    • Use a pair of blunt tweezers to lift the motherboard out from underneath the plastic clips towards the buttons.
    • Remove the motherboard.
Sonuç
If possible, turn on your device and test your repair before resealing.
2 farklı kişi bu kılavuzu tamamladı.
Tobias Isakeit
124.396 İtibar
189 adet Kılavuz yazıldı
Ekip
1Rehber Yorum
What is the cost of R845 mother board of Samsung watch 3- 45 mm
Jayanta Roy - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 47
Her zaman: 2,671
