Giriş
This guide shall detail and illustrate how to replace the charging port and headphone jack for a Samsung Galaxy Y in the situation of either part not working.
Neye ihtiyacın var
Use the blue plastic opening tool to pry the back-panel off of the device.
Use the screwdriver with a PH000 screwdriver head to remove the four 5mm screws located in the corner of the interior back panel.
Remove the SD card as well by sliding the card out of it's slot.
Bir başkası bu kılavuzu tamamladı.
