Ana içeriğe geç
Samsung Galaxy Y Charging port and headphone jack Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Y Charging port and headphone jack Replacement, Back Panel: adım 1, 3 resimden 1. Samsung Galaxy Y Charging port and headphone jack Replacement, Back Panel: adım 1, 3 resimden 2. Samsung Galaxy Y Charging port and headphone jack Replacement, Back Panel: adım 1, 3 resimden 3.
    • Use the blue plastic opening tool to pry the back-panel off of the device.
  2. Samsung Galaxy Y Charging port and headphone jack Replacement, Charging port and headphone jack: adım 2, 3 resimden 1. Samsung Galaxy Y Charging port and headphone jack Replacement, Charging port and headphone jack: adım 2, 3 resimden 2. Samsung Galaxy Y Charging port and headphone jack Replacement, Charging port and headphone jack: adım 2, 3 resimden 3.
    • Use the screwdriver with a PH000 screwdriver head to remove the four 5mm screws located in the corner of the interior back panel.
    • Remove the SD card as well by sliding the card out of it's slot.
  3. Samsung Galaxy Y Charging port and headphone jack Replacement: adım 3, 3 resimden 1. Samsung Galaxy Y Charging port and headphone jack Replacement: adım 3, 3 resimden 2. Samsung Galaxy Y Charging port and headphone jack Replacement: adım 3, 3 resimden 3.
    • Use metal pry tool to separate the interior back panel from the interior hardware and screen.
  4. Samsung Galaxy Y Charging port and headphone jack Replacement: adım 4, 3 resimden 1. Samsung Galaxy Y Charging port and headphone jack Replacement: adım 4, 3 resimden 2. Samsung Galaxy Y Charging port and headphone jack Replacement: adım 4, 3 resimden 3.
    • Disconnect the orange motherboard connection, then remove interior hardware from the front screen display.
  5. Samsung Galaxy Y Charging port and headphone jack Replacement: adım 5, 3 resimden 1. Samsung Galaxy Y Charging port and headphone jack Replacement: adım 5, 3 resimden 2. Samsung Galaxy Y Charging port and headphone jack Replacement: adım 5, 3 resimden 3.
    • Use a Phillips #000 screwdriver to remove the five 2mm screws located in the corner of the silver protective panel.
    • If the motherboard is cracked or damaged, then replace with a new one.
  6. Samsung Galaxy Y Charging port and headphone jack Replacement: adım 6, 3 resimden 1. Samsung Galaxy Y Charging port and headphone jack Replacement: adım 6, 3 resimden 2. Samsung Galaxy Y Charging port and headphone jack Replacement: adım 6, 3 resimden 3.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 17
Her zaman: 751
