Ana içeriğe geç
Samsung Gear 2 Motherboard Replacement
Neye ihtiyacın var
  1. Samsung Gear 2 Motherboard Replacement, Front half and Back half: adım 1, 2 resimden 1. Samsung Gear 2 Motherboard Replacement, Front half and Back half: adım 1, 2 resimden 2.
    • Before disassembling your Gear, be sure it is powered off.
    • To remove each strap, locate the metal latches on both sides of the back of the Gear.
    • Press down on the metal latch while pulling the strap away from the Gear until it is completely off.
  2. Samsung Gear 2 Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the four 4.0 mm screws on the back of the Gear using a T5 Torx Screwdriver.
  3. Samsung Gear 2 Motherboard Replacement: adım 3, 3 resimden 1. Samsung Gear 2 Motherboard Replacement: adım 3, 3 resimden 2. Samsung Gear 2 Motherboard Replacement: adım 3, 3 resimden 3.
    • Firmly holding the Gear, insert the flat side of the spudger at an angle to pry the back casing off of the device. Move the spudger along the sides of the Gear to completely detach the back and front components.
    • Pry the device open from the other side also if it does not fully disassemble from one side.
  4. Samsung Gear 2 Motherboard Replacement, Camera: adım 4, 2 resimden 1. Samsung Gear 2 Motherboard Replacement, Camera: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Locate the rectangular metal connector that attaches the camera to the Gear.
    • Use tweezers to gently lift and detach the metal plate of the connector.
    • When reassembling the Gear, reattach the camera connector by carefully aligning the metal plate and its pins to its original placement. Make sure it snaps in place to avoid improper connections and possible damage.
  5. Samsung Gear 2 Motherboard Replacement: adım 5, 1 resimden 1.
    • Use tweezers to carefully lift the camera from its slot out of the case.
    Cool! But were can i buy a camara for the watch?
    jorge - Yanıt
    Did you find a place to buy the camera? Mine broke today
    warakurna -
  6. Samsung Gear 2 Motherboard Replacement, Motherboard: adım 6, 2 resimden 1. Samsung Gear 2 Motherboard Replacement, Motherboard: adım 6, 2 resimden 2.
    • Use tweezers to grab and then gently lift up the metal plate of the safety belt.
    • When removing the metal plate, be sure to remove them carefully as to not rip the orange tape that is attached to them.
    • During reassembly, be sure to line up the pins of the metal plate in order to reattach correctly.
    There are actually TWO metal plates attached on mine, not one, but they both came away easily, and were both easy to put back.
    anthony - Yanıt
  7. Samsung Gear 2 Motherboard Replacement: adım 7, 2 resimden 1. Samsung Gear 2 Motherboard Replacement: adım 7, 2 resimden 2.
    • Once the safety belt is removed, use tweezers to take the motherboard out of the Gear 2.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Allison Michel
513 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-27, Maness Spring 2014 Cal Poly, Team 13-27, Maness Spring 2014 üyesi
CPSU-MANESS-S14S13G27
4 Üyeler
6 adet Kılavuz yazıldı
1Rehber Yorum
Can I send my gear 2 to you to repair the contacts on the back of the watch? The R380 cradle is in perfect shape the contacts on the watch has one contact worn and it will not charge help butchmcleod@hotmail.com
Butch McLeod - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 3,480
