Ana içeriğe geç
Samsung HMX-QF20 Internal Microphone Replacement
Ian Dorset
Ian Dorset ve 3 diğer katkıda bulunanlar
En son October 29, 2020 tarihinde güncellendi
Tahmin yok
Zor
İşlem Görüntüleri
Eksik Adımlar
Eksik Ayrıntılar
Before replacing, make sure the microphone is not being covered by your hand during filming, as this will muffle the audio.
Neye ihtiyacın var
Aletler
  1. Samsung HMX-QF20 Internal Microphone Replacement, Lens: adım 1, 1 resimden 1.
    • Remove the 4 mm screw on the underside of the camcorder near the tripod mount.
  2. Samsung HMX-QF20 Internal Microphone Replacement: adım 2, 1 resimden 1.
    • Remove the 4 mm screw next to the buckle of the hand strap closest to the lens.
  3. Samsung HMX-QF20 Internal Microphone Replacement: adım 3, 1 resimden 1.
    • Open the LCD screen. Remove the 4 mm screw on the inside panel, located at top left corner.
  4. Samsung HMX-QF20 Internal Microphone Replacement: adım 4, 1 resimden 1.
    • Firmly grip and pull the front casing on the lens to remove it.
    • Be sure to remove the front casing at gently as possible to prevent damaging the attached ribbon cable. If not careful, the ribbon cables could be torn.
  5. Samsung HMX-QF20 Internal Microphone Replacement: adım 5, 1 resimden 1.
    • Remove the three 5 mm screws surrounding the lens.
Sonuç
Ian Dorset
225 İtibar
2 adet Kılavuz yazıldı
Ekip
Marist, Team 1-5, Laflen Spring 2015 Marist, Team 1-5, Laflen Spring 2015 üyesi
MARS-LAFLEN-S15S1G5
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 454
