Ana içeriğe geç
Samsung HMX-W300 LCD Screen Replacement
Robert
Robert ve 5 diğer katkıda bulunanlar
En son November 1, 2020 tarihinde güncellendi
35 dakika
Zor
Shows how to place LCD screen of the camera via words and pictures. Replacement of LCD screen requires the removal of motherboard.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Samsung HMX-W300 LCD Screen Replacement, Disassembling Samsung HMX-W300: adım 1, 3 resimden 1. Samsung HMX-W300 LCD Screen Replacement, Disassembling Samsung HMX-W300: adım 1, 3 resimden 2. Samsung HMX-W300 LCD Screen Replacement, Disassembling Samsung HMX-W300: adım 1, 3 resimden 3.
    • To remove the wristband of the device, grab the middle loop and pull the band through.
  2. Samsung HMX-W300 LCD Screen Replacement: adım 2, 2 resimden 1. Samsung HMX-W300 LCD Screen Replacement: adım 2, 2 resimden 2.
    • Remove four screws with a Hex 1.5 mm screwdriver.
  3. Samsung HMX-W300 LCD Screen Replacement: adım 3, 3 resimden 1. Samsung HMX-W300 LCD Screen Replacement: adım 3, 3 resimden 2. Samsung HMX-W300 LCD Screen Replacement: adım 3, 3 resimden 3.
    • Open the HDMI door on the side of the camera.
    • Remove the single screw using a Phillips #00 screwdriver.
  4. Samsung HMX-W300 LCD Screen Replacement: adım 4, 3 resimden 1. Samsung HMX-W300 LCD Screen Replacement: adım 4, 3 resimden 2. Samsung HMX-W300 LCD Screen Replacement: adım 4, 3 resimden 3.
    • Use the iFixit opening tool on both sides on the device. Pry apart both sections with light force.
    • Do not apply too much force. There is a wire that attaches the front case with the rear case that can be damaged.
  5. Samsung HMX-W300 LCD Screen Replacement: adım 5, 3 resimden 1. Samsung HMX-W300 LCD Screen Replacement: adım 5, 3 resimden 2. Samsung HMX-W300 LCD Screen Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Pull the wire ribbon out with a pair of tweezers.
  6. Samsung HMX-W300 LCD Screen Replacement, Remove tape.: adım 6, 3 resimden 1. Samsung HMX-W300 LCD Screen Replacement, Remove tape.: adım 6, 3 resimden 2. Samsung HMX-W300 LCD Screen Replacement, Remove tape.: adım 6, 3 resimden 3.
  7. Samsung HMX-W300 LCD Screen Replacement, Unplug wire ribbon.: adım 7, 2 resimden 1. Samsung HMX-W300 LCD Screen Replacement, Unplug wire ribbon.: adım 7, 2 resimden 2.
    • Use tweezers to grab the wire ribbon, then pull the wire out of connection.
  8. Samsung HMX-W300 LCD Screen Replacement, Remove scerws.: adım 8, 2 resimden 1. Samsung HMX-W300 LCD Screen Replacement, Remove scerws.: adım 8, 2 resimden 2.
    • There are 5 Phillips size 00 screws. Remove all 5 screws.
    • Wire ribbon is attached to the motherboard.
  9. Samsung HMX-W300 LCD Screen Replacement: adım 9, 1 resimden 1.
    • Pry the motherboard up using the plastic opening tool.
    • Be careful there is a wire ribbon holding the motherboard.
  10. Samsung HMX-W300 LCD Screen Replacement, Disconnect wire ribbon.: adım 10, 2 resimden 1. Samsung HMX-W300 LCD Screen Replacement, Disconnect wire ribbon.: adım 10, 2 resimden 2.
    • Use tweezers to disconnect the wire as shown. This will loosen the motherboard from the rear case.
  11. Samsung HMX-W300 LCD Screen Replacement, Remove screws.: adım 11, 3 resimden 1. Samsung HMX-W300 LCD Screen Replacement, Remove screws.: adım 11, 3 resimden 2. Samsung HMX-W300 LCD Screen Replacement, Remove screws.: adım 11, 3 resimden 3.
    • Use Phillips size 00 and remove the 3 screws as shown.
  12. Samsung HMX-W300 LCD Screen Replacement, Pry screen.: adım 12, 2 resimden 1. Samsung HMX-W300 LCD Screen Replacement, Pry screen.: adım 12, 2 resimden 2.
    • Pry the end of the screen with the plastic opening tool.
  13. Samsung HMX-W300 LCD Screen Replacement: adım 13, 3 resimden 1. Samsung HMX-W300 LCD Screen Replacement: adım 13, 3 resimden 2. Samsung HMX-W300 LCD Screen Replacement: adım 13, 3 resimden 3.
    • Grab the end of the screen, then pull towards the inside of the case. This is a bit tricky. This will release tabs at the top of the screen to the rear case.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Robert
966 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-2, Blackwell Winter 2015 USF Tampa, Team 9-2, Blackwell Winter 2015 üyesi
USFT-BLACKWELL-W15S9G2
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 412
