Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
This guide will require you to disassemble the back and side panel of the printer. You will need to refer to the Removing Samsung ML2510 Back Panel guide in order to complete the task.
Neye ihtiyacın var
Remove the top hinged panel by taking out the pins at the bottom of this panel.
Remove front panel by gently moving the holes on the panel from the pegs attached to the main printer body, one at a time.
2 farklı kişi bu kılavuzu tamamladı.
