Ana içeriğe geç
Samsung MV900F Flash Bulb Assembly Replacement
Justin Smith
Justin Smith ve 2 diğer katkıda bulunanlar
En son May 7, 2024 tarihinde güncellendi
15 - 30 dakika
Orta
Daha iyi giriş
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
  1. Samsung MV900F Flash Bulb Assembly Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the lock towards the middle of the camera, in the same direction of the arrow.
  2. Samsung MV900F Flash Bulb Assembly Replacement: adım 2, 1 resimden 1.
    • Push the blue battery holder up in the direction of the arrow.
  3. Samsung MV900F Flash Bulb Assembly Replacement: adım 3, 1 resimden 1.
    • Pull the battery out of the battery slot.
  4. Samsung MV900F Flash Bulb Assembly Replacement, Screen: adım 4, 2 resimden 1. Samsung MV900F Flash Bulb Assembly Replacement, Screen: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use tweezers to remove the four rubber screw covers.
  5. Samsung MV900F Flash Bulb Assembly Replacement: adım 5, 2 resimden 1. Samsung MV900F Flash Bulb Assembly Replacement: adım 5, 2 resimden 2.
    • Remove the four Phillips 2.381 mm screws on back side of camera and one Phillips 2.381 mm screw on the bottom of the camera, using a Phillips #00 screwdriver.
  6. Samsung MV900F Flash Bulb Assembly Replacement: adım 6, 1 resimden 1.
    • Remove the back casing by just carefully pulling the casing off of the camera.
  7. Samsung MV900F Flash Bulb Assembly Replacement: adım 7, 1 resimden 1.
    • Use the Phillips #00 screw driver to remove the four 2.381 mm screws next to the screen hinge.
  8. Samsung MV900F Flash Bulb Assembly Replacement: adım 8, 1 resimden 1.
    • Use plastic opening tool to disconnect screen connector from the control board.
  9. Samsung MV900F Flash Bulb Assembly Replacement: adım 9, 1 resimden 1.
    • Remove the old screen.
  10. Samsung MV900F Flash Bulb Assembly Replacement, Lens Assembly: adım 10, 1 resimden 1.
    • Remove the 2.381 mm screw with a Phillips #00 screwdriver.
  11. Samsung MV900F Flash Bulb Assembly Replacement: adım 11, 1 resimden 1.
    • Use the plastic opening tool to remove the silver metal lens cover.
  12. Samsung MV900F Flash Bulb Assembly Replacement: adım 12, 1 resimden 1.
    • Use the tweezers to remove the black electrical tape covering the copper connector to the control board.
  13. Samsung MV900F Flash Bulb Assembly Replacement: adım 13, 1 resimden 1.
    • From the front of the camera, push the lens through the back of the camer.a
  14. Samsung MV900F Flash Bulb Assembly Replacement: adım 14, 2 resimden 1. Samsung MV900F Flash Bulb Assembly Replacement: adım 14, 2 resimden 2.
    • Use a pair of tweezers to flip up the black retaining bar on each of the two ZIF connectors.
  15. Samsung MV900F Flash Bulb Assembly Replacement: adım 15, 2 resimden 1. Samsung MV900F Flash Bulb Assembly Replacement: adım 15, 2 resimden 2.
    • Remove the lens assembly from the camera.
  16. Samsung MV900F Flash Bulb Assembly Replacement, Flash Bulb Assembly: adım 16, 1 resimden 1.
    • Remove the 2.381 mm screw that is holding the copper to the control board with a Phillips #00 screw driver.
  17. Samsung MV900F Flash Bulb Assembly Replacement: adım 17, 1 resimden 1.
    • Use tweezers to pull copper connector from the control board.
  18. Samsung MV900F Flash Bulb Assembly Replacement: adım 18, 1 resimden 1.
    • Use the plastic opening tool to pry the control board up, thus allowing the flash bulb assembly to be removed.
  19. Samsung MV900F Flash Bulb Assembly Replacement: adım 19, 1 resimden 1.
    • Beginning with the battery on the side, gently pull upwards to remove the entire flash bulb assembly.
Sonuç
Justin Smith
110 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 6
Her zaman: 368
