Giriş
In order to maximize the memory RAM on a computer, it needs to be replaced with a new one.
Neye ihtiyacın var
Locate the external battery on the bottom side of the device.
Locate the tab on the right side of the battery.
Shift the tab to the left.
Locate the 14, 3.93 mm, screws that need to be removed on the base of the computer.
You are now able to carefully detach the fan from the base.
Hello.
Your explanation is right and clear, except you omit to indicate that, when removing the fan, we remove the radiator and break the thermal paste, then it should be replaced, cleaning the two chips (proc and bridge) and the radiator to apply a new fresh thermal paste.
After detaching the fan, you are now able to remove the RAM by extending the two side bars out
3 farklı kişi bu kılavuzu tamamladı.
