Giriş
This guide provides details on how to remove a dirty or broken fan from the Samsung device.
Neye ihtiyacın var
Remove the ten 6.6mm Philips#00 screws securing the lower case to the upper case.
Loosen but don't remove the 7 silver Phillips #00 3.5mm screws securing the fan to the motherboard. They should detach from the motherboard and remain attached to the fan assembly.
Bir başkası bu kılavuzu tamamladı.
