Ana içeriğe geç
Samsung NP900X4B Battery Replacement
Neye ihtiyacın var
  1. Samsung NP900X4B Battery Replacement, Battery: adım 1, 2 resimden 1. Samsung NP900X4B Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Ensure computer is unplugged and powered down before continuing.
    • Remove the ten screws along the base using a Phillips #000.
    • Use a Plastic Opening Tool to pry open the base .
  2. Samsung NP900X4B Battery Replacement: adım 2, 1 resimden 1.
    • The battery is now unobstructed from your view.
    • Before removing the battery, use the plastic opening tool to detach the ribbon wire cable that connects the battery to the motherboard.
  3. Samsung NP900X4B Battery Replacement: adım 3, 2 resimden 1. Samsung NP900X4B Battery Replacement: adım 3, 2 resimden 2.
    • Use the Phillips #000 screwdriver to remove six screws that are holding the battery in place.
  4. Samsung NP900X4B Battery Replacement: adım 4, 1 resimden 1.
    • Lift and pull out the battery.
Sonuç
Nathan LeBlanc
109 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G6, Valliere Fall 2018 UMass Dartmouth, Team S4-G6, Valliere Fall 2018 üyesi
UMASSD-VALLIERE-F18S4G6
5 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 643
