Giriş
Is the button panel on your camera unresponsive? Are your buttons dirty, cracked or missing? This guide will show you how to access the button panel on your camera in order to make necessary repairs.
Neye ihtiyacın var
Orient the camera so the button panel and LCD are facing you.
Use a spudger or fingernail to open the battery compartment on the right side of the camera.
Use a Phillips #00 screwdriver to remove the 4 mm screw inside the battery compartment.
Bu adımda kullanılan alet:Tweezers$4.99
Gently flip the sensor cover back to expose the screw attaching the sensor cover to the ribbon cable.
Use a Phillips #00 screwdriver to remove the 3 mm screw from the sensor cover.
Use tweezers to remove the metal contact cover. Be sure to carefully remove the cover so the gold contacts remain in place.
Use a Phillips #00 screwdriver to remove the 3 mm screw located below the wifi antenna.
Remove the three 4 mm Phillips #00 screws securing the button panel to the camera case.
