Ana içeriğe geç
Samsung NX Mini Front Case Replacement
Neye ihtiyacın var
  1. Samsung NX Mini Front Case Replacement, Battery: adım 1, 3 resimden 1. Samsung NX Mini Front Case Replacement, Battery: adım 1, 3 resimden 2. Samsung NX Mini Front Case Replacement, Battery: adım 1, 3 resimden 3.
    • Orient the camera so the button panel and LCD are facing you.
    • Use a spudger or fingernail to open the battery compartment on the right side of the camera.
  2. Samsung NX Mini Front Case Replacement: adım 2, 2 resimden 1. Samsung NX Mini Front Case Replacement: adım 2, 2 resimden 2.
    • Push the blue trapdoor to the left to release the battery, and remove the battery.
    • There is no battery shown in this photo.
  3. Samsung NX Mini Front Case Replacement, Front Case: adım 3, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the 4 mm screw inside the battery compartment.
  4. Samsung NX Mini Front Case Replacement: adım 4, 1 resimden 1.
    • Remove the 4 mm Phillips #00 screw hiding in the external flash port.
  5. Samsung NX Mini Front Case Replacement: adım 5, 1 resimden 1.
    • Remove the four 5 mm Phillips #00 screws from the lens assembly.
  6. Samsung NX Mini Front Case Replacement: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Remove the metal lens mount by hand or with tweezers.
    • Be careful not to touch the sensor in the center of the lens assembly.
  7. Samsung NX Mini Front Case Replacement: adım 7, 1 resimden 1.
    • Use tweezers to remove the inner metal ring.
  8. Samsung NX Mini Front Case Replacement: adım 8, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the three 4 mm screws from the bottom of the case.
  9. Samsung NX Mini Front Case Replacement: adım 9, 2 resimden 1. Samsung NX Mini Front Case Replacement: adım 9, 2 resimden 2.
    • Use your hands to slowly pull the front casing away from the camera.
    • The case is attached with multiple clips that may make a cracking noise as you pull it away from the camera.
Sonuç
Kelsea Weber
20.607 İtibar
32 adet Kılavuz yazıldı
Ekip
iFixit, Team S1-G1, Weber Summer 2018 iFixit, Team S1-G1, Weber Summer 2018 üyesi
FIX-WEBER-SU18S1G1
5 Üyeler
43 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 635
