Ana içeriğe geç
Samsung NX3000 Back Case Replacement
Neye ihtiyacın var
  1. Samsung NX3000 Back Case Replacement, Battery: adım 1, 3 resimden 1. Samsung NX3000 Back Case Replacement, Battery: adım 1, 3 resimden 2. Samsung NX3000 Back Case Replacement, Battery: adım 1, 3 resimden 3.
    • Turn the camera upside down. Only remove the lens if you have to in order to access the battery compartment, as dust particles could easily enter the main body and fall onto the delicate sensor.
    • Slide the button to the left to open the battery compartment.
    • Push the blue button up to release the battery.
    • The battery is not shown in these photos.
  2. Samsung NX3000 Back Case Replacement, Lens Assembly: adım 2, 2 resimden 1. Samsung NX3000 Back Case Replacement, Lens Assembly: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Remove the four 7.3 mm Phillips screws from the front of the lens assembly.
    • Remove the silver ring with tweezers.
  3. Samsung NX3000 Back Case Replacement: adım 3, 2 resimden 1. Samsung NX3000 Back Case Replacement: adım 3, 2 resimden 2.
    • Use tweezers to remove the black plastic ring and small metal ring inside the lens assembly.
  4. Samsung NX3000 Back Case Replacement: adım 4, 3 resimden 1. Samsung NX3000 Back Case Replacement: adım 4, 3 resimden 2. Samsung NX3000 Back Case Replacement: adım 4, 3 resimden 3.
    • Use tweezers to lift the pyramid screw and spring from the lens assembly.
  5. Samsung NX3000 Back Case Replacement, Back Case: adım 5, 2 resimden 1. Samsung NX3000 Back Case Replacement, Back Case: adım 5, 2 resimden 2.
    • Remove the three 4.3 mm Phillips screws from the bottom of the camera.
    • Remove the 4.3 mm Phillips screw hiding inside the battery compartment.
  6. Samsung NX3000 Back Case Replacement: adım 6, 2 resimden 1. Samsung NX3000 Back Case Replacement: adım 6, 2 resimden 2.
    • Remove the 4.2 mm Phillips screw from the left handgrip.
    • Remove the two 4.2 mm Phillips screws from the right handgrip.
  7. Samsung NX3000 Back Case Replacement: adım 7, 2 resimden 1. Samsung NX3000 Back Case Replacement: adım 7, 2 resimden 2.
    • Use tweezers to remove the metal shield from the external flash mount.
  8. Samsung NX3000 Back Case Replacement: adım 8, 1 resimden 1.
    • Remove the four 5 mm Phillips screws from the external flash mount .
  9. Samsung NX3000 Back Case Replacement: adım 9, 2 resimden 1. Samsung NX3000 Back Case Replacement: adım 9, 2 resimden 2.
    • Remove the external flash mount.
  10. Samsung NX3000 Back Case Replacement: adım 10, 2 resimden 1. Samsung NX3000 Back Case Replacement: adım 10, 2 resimden 2.
    • Slowly pull the bottom of the back case away from the camera.
    • Do not attempt to remove the back case as it is attached to the motherboard by a ribbon cable.
  11. Samsung NX3000 Back Case Replacement: adım 11, 3 resimden 1. Samsung NX3000 Back Case Replacement: adım 11, 3 resimden 2. Samsung NX3000 Back Case Replacement: adım 11, 3 resimden 3.
    • Use the flat end of a spudger to pry the flat topped connector straight up from the motherboard.
    • Remove the back case.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Kelsea Weber
21.077 İtibar
32 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 34
Her zaman: 1,497
