Ana içeriğe geç
Samsung PL200 SD card Replacement
Jacob Presnell
Jacob Presnell ve 6 diğer katkıda bulunanlar
En son January 10, 2025 tarihinde güncellendi
2 dakika
Çok kolay
Daha iyi giriş
Replace the SD card on your Samsung PL200 to provide more memory space as well as replacing a defective card.
  1. Samsung PL200 SD card Replacement, SD card: adım 1, 2 resimden 1. Samsung PL200 SD card Replacement, SD card: adım 1, 2 resimden 2.
    • Push the battery cover over to access battery/SD card compartment on the bottom.
    • There is a sliding release button (labeled 'OPEN') that can be slid sideways to open the battery/SD card compartment.
    • Slide this button in the direction that the arrow is pointing to release and open the spring loaded battery/sd compartment door.
  2. Samsung PL200 SD card Replacement: adım 2, 2 resimden 1. Samsung PL200 SD card Replacement: adım 2, 2 resimden 2.
    • Once the battery/SD card compartment is opened, simply push the SD card down to activate the spring loaded ejector to raise SD card.
    • Use your fingers to remove the old SD card.
    • Insert the new SD card into the SD card slot and push it down all the way until it clicks and remains flush with battery.
    • Close the battery/SD card compartment.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jacob Presnell
219 İtibar
2 adet Kılavuz yazıldı
Ekip
Clemson, Team 15-7, Shirley Winter 2015 Clemson, Team 15-7, Shirley Winter 2015 üyesi
CLEM-SHIRLEY-W15S15G7
5 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 437
