Ana içeriğe geç
Samsung RC512 Screen Replacement
Neye ihtiyacın var
  1. Samsung RC512 Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Place the laptop upside down.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung RC512 Screen Replacement: adım 2, 2 resimden 1. Samsung RC512 Screen Replacement: adım 2, 2 resimden 2.
    • Locate two notches above the battery.
    • Slide both battery locking notches to either side to remove the battery.
    • Pull the battery out.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung RC512 Screen Replacement, Screen: adım 3, 3 resimden 1. Samsung RC512 Screen Replacement, Screen: adım 3, 3 resimden 2. Samsung RC512 Screen Replacement, Screen: adım 3, 3 resimden 3.
    • The Laptop should be off before removing the battery.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung RC512 Screen Replacement: adım 4, 3 resimden 1. Samsung RC512 Screen Replacement: adım 4, 3 resimden 2. Samsung RC512 Screen Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Remove the gray covers with tweezers to expose the 4mm screws.
    • Using a Phillips #0 screwdriver, remove the four 4 mm Phillips #0 screws.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung RC512 Screen Replacement: adım 5, 2 resimden 1. Samsung RC512 Screen Replacement: adım 5, 2 resimden 2.
    • Insert the blue plastic opening tool into the bezel and rear housing of the screen.
    • Use the plastic opening tool to pop open the claps that hold the casing on the screen.
    • Work your way around the sides carefully and continue this to the bottom.
    • You may use your fingers to help remove the cover.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung RC512 Screen Replacement: adım 6, 2 resimden 1. Samsung RC512 Screen Replacement: adım 6, 2 resimden 2.
    • With the Phillips #0 screwdriver remove the six 3 mm screws, which mount the screen onto the base of the laptop.
    • As you remove the last two screws, support the screen. As the screws are taken out, the screen will begin to fall forward.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung RC512 Screen Replacement: adım 7, 3 resimden 1. Samsung RC512 Screen Replacement: adım 7, 3 resimden 2. Samsung RC512 Screen Replacement: adım 7, 3 resimden 3.
    • Gently lay the LCD onto the keyboard.
    • Do not separate the LCD screen and the back panel from each other. The video connector still connects the two together.
    • Remove the tape that secures the video connector to the LCD screen with tweezers.
    • Grasp the video connector at its base and pull it away from the LCD screen.
    • The only thing holding the screen will be the clear tape causing it to come out easily.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
jando
917 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 18-2, Blackwell Fall 2016 USF Tampa, Team 18-2, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S18G2
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 24
Her zaman: 1,069
